this used to work but cant install?
Postby comfarol » Tue Oct 02, 2018 1:58 pm
before this the program would close or stop working after long system up time
Any why are the w10 drivers buried in a forum post, viewtopic.php?f=2&t=308
comfarol
Re: this used to work but cant install?
Postby TheLaGmAn » Wed Oct 03, 2018 3:56 pm
The drivers are in the GOverlay folder inside LCDSysInfo2\Driver.
Those are the ones you should use, following our guide.
Those other drivers are suggestions from users, you can use as well.
Postby comfarol » Wed Oct 10, 2018 12:24 pm
same problem
comfarol
Postby TheLaGmAn » Fri Oct 12, 2018 6:33 pm
did you disable driver signature as per our guide?
http://www.goverlay.com/content/faq/
Postby comfarol » Mon Oct 15, 2018 6:56 am
yes I did, I had it working before. The program kept closing after long system uptime and needed to be restarted, then I stopped reopening it because it got annoying. Now i wanted it working again so I uninstalled the drivers to reinstall to try fix it but can't.
comfarol
Postby TheLaGmAn » Tue Oct 16, 2018 9:56 pm
The driver should work, we can do a teavmiewer session if you want to i can try to install the driver, send me an email to support@goverlay.com
Postby CybaGirl » Tue Oct 23, 2018 5:38 am
Hello,
Have you tried opening device manager and deleting the driver from there?
I once had an issue with a USB memory disk and no matter what I did I could never get it to work. I was about to throw it and then I read somewhere to delete the old driver this way. Once I did this and rebooted my computer I then plugged the USB memory stick back in and the driver installed and I was able to use the memory stick again :).
CybaGirl
Postby comfarol » Tue Oct 23, 2018 9:27 pm
Yea thats where I had uninstalled the driver from.
I can teamviewer, Ill send you an email when im ready. Currently on mobile data and it sucks.
comfarol
Postby comfarol » Wed Nov 28, 2018 5:51 am
Hey i really need that support my LCD is flashing and its pretty annoying -.- sending email now
comfarol
Postby comfarol » Wed Nov 28, 2018 9:52 am
sorted it, not really a fan of it breaking everytime there is a windows update ay and there is still no vertical support. just simple rotate would be nice
comfarol
