Energy saving mode and un usable screen.
Postby taco smush » Wed Oct 22, 2014 12:36 am
So i had a lot of luck on day one when i set it up and ever since then i have had issues with it going into energy saving mode on its own or if it does display something after i go into the in windows settings and click save and apply it only shows random info. (one of your pre defined CPU sensor readouts) Ive tried different settings, have it set to run as administrator, have riva set to start with this in startup. Tried running the goverlay tester and will post the log below, Please help i love this lil guy and it really sucks i havent been able to use it like i did on day one.
at the bottom of the tester app for LCDsysinfo for GOverlay it says Cant Connect so i am assuming and hoping this is something really stupid..
------------- OS Info ------------
--> Version: 6.1.7601.65536
--> Name: Microsoft Windows 7 Professional
--> Windows is 64 bits
------------- File Drivers Check ------------
System32 located at: C:\Windows\system32\
LibUsb0.dll found
--> Version: 1.2.2.0
drivers\libusb0.sys found
------------- LibUsb Driver Status ------------
LibUsb Kernel version: 1.2.2.0
------------- Related Devices Connected ------------
--> LCDsysinfo for GOverlay
----> Service: libusb0
----> Description: LCDsysinfo for GOverlay
----> Manufacturer: Coldtears Electronics
----> DeviceID: USB\VID_20A0&PID_41EC\LCDSZ
----> Status: 0
------------- Devices Detected ------------
Device: #0 (Coldtears Electronics - LCDsysinfo for GOverlay)
-> Pid: 16876
-> Vid: 8352
-> Product: LCDsysinfo (GOverlay)
-> Manufacturer: coldtears electronics
-> SerialString: lcdsz
-> Is Open: True
-> IsAlive: True
-> Name: LCDsysinfo for GOverlay
-> Rev: 100
-> DeviceDesc: LCDsysinfo for GOverlay
-> HardwareId: System.String[]
-> CompatibleIds: System.String[]
-> Class: libusb-win32 devices
-> ClassGuid: {eb781aaf-9c70-4523-a5df-642a87eca567}
-> Driver: {eb781aaf-9c70-4523-a5df-642a87eca567}\0000
-> Mfg: Coldtears Electronics
-> FriendlyName:
-> LocationInformation: Port_#0001.Hub_#0003
-> PhysicalDeviceObjectName: \Device\000000b4
-> BusTypeGuid: 9d7debbc-c85d-11d1-9eb4-006008c3a19a
-> LegacyBusType: 15
-> BusNumber: 0
-> EnumeratorName: USB
-> Address: 1
-> UiNumber: 0
-> InstallState: 0
-> RemovalPolicy: 3
-> SymbolicName: USB\VID_20A0&PID_41EC&REV_0100
-> Connection Tests:
----> Connection Failed
----> Connection Try #2 Succeded
----> Connection Try #3 Failed
----> Connection Try #4 Succeded
----> Errors: 0:
------------- LibUsb Utility Devices Report ------------
Dev #1: coldtears electronics - LCDsysinfo (GOverlay) - Serial Number: lcdsz
bLength: 18
bDescriptorType: 01h
bcdUSB: 0110h
bDeviceClass: FFh
bDeviceSubClass: 00h
bDeviceProtocol: 00h
bMaxPacketSize0: 08h
idVendor: 20A0h
idProduct: 41ECh
bcdDevice: 0100h
iManufacturer: 1
iProduct: 2
iSerialNumber: 3
bNumConfigurations: 1
wTotalLength: 18
bNumInterfaces: 1
bConfigurationValue: 1
iConfiguration: 0
bmAttributes: 80h
MaxPower: 50
bInterfaceNumber: 0
bAlternateSetting: 0
bNumEndpoints: 0
bInterfaceClass: 0
bInterfaceSubClass: 0
bInterfaceProtocol: 0
iInterface: 0
------------- Listing all USB Connected Devices ------------
--> USB Root Hub
----> Service: usbhub
----> Description: USB Root Hub
----> Manufacturer: (Standard USB Host Controller)
----> DeviceID: USB\ROOT_HUB20\4&1931BC7&0
----> Status: 0
--> Generic USB Hub
----> Description: Generic USB Hub
----> Manufacturer: (Generic USB Hub)
----> DeviceID: USB\VID_8087&PID_8000\5&2B2D6535&0&1
----> Status: 0
--> USB Root Hub
----> DeviceID: USB\ROOT_HUB20\4&379617F&0
----> Status: 0
--> Generic USB Hub
----> DeviceID: USB\VID_8087&PID_8008\5&126C55C1&0&1
----> Status: 0
--> Intel(R) USB 3.0 Root Hub
----> Service: iusb3hub
----> Description: Intel(R) USB 3.0 Root Hub
----> Manufacturer: Intel(R) Corporation
----> DeviceID: IUSB3\ROOT_HUB30\4&419A9D0&0
----> Status: 0
--> USB Composite Device
----> Service: usbccgp
----> Description: USB Composite Device
----> DeviceID: USB\VID_1532&PID_0021\5&30B7B990&0&6
----> Status: 0
--> Razer Naga Epic Dock
----> Service: HidUsb
----> Description: Razer Naga Epic Dock
----> Manufacturer: Razer Inc
----> DeviceID: USB\VID_1532&PID_0021&MI_00\6&719CC11&0&0000
----> Status: 0
----> Service: mouhid
----> DeviceID: HID\VID_1532&PID_0021&MI_00\7&2E47EED0&0&0000
----> Status: 0
--> USB Input Device
----> Description: USB Input Device
----> Manufacturer: (Standard system devices)
----> DeviceID: USB\VID_1532&PID_0021&MI_01\6&719CC11&0&0001
----> Status: 0
----> Service: kbdhid
----> DeviceID: HID\VID_1532&PID_0021&MI_01&COL01\7&1B17D292&0&0000
----> Status: 0
--> HID-compliant consumer control device
----> Service:
----> Description: HID-compliant consumer control device
----> Manufacturer: Microsoft
----> DeviceID: HID\VID_1532&PID_0021&MI_01&COL02\7&1B17D292&0&0001
----> Status: 0
--> HID-compliant device
----> Service:
----> Description: HID-compliant device
----> DeviceID: HID\VID_1532&PID_0021&MI_01&COL03\7&1B17D292&0&0002
----> Status: 0
----> DeviceID: USB\VID_1532&PID_002E\5&30B7B990&0&7
----> Status: 0
--> Razer Naga
----> DeviceID: USB\VID_1532&PID_002E&MI_00\6&2236CB93&0&0000
----> Status: 0
--> Razer Naga
----> DeviceID: HID\VID_1532&PID_002E&MI_00\7&369D4DCE&0&0000
----> Status: 0
----> DeviceID: USB\VID_1532&PID_002E&MI_01\6&2236CB93&0&0001
----> Status: 0
--> Razer Naga
----> DeviceID: HID\VID_1532&PID_002E&MI_01&COL01\7&2E55E062&0&0000
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_002E&MI_01&COL02\7&2E55E062&0&0001
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_002E&MI_01&COL03\7&2E55E062&0&0002
----> Status: 0
--> USB 2.0 Hub
----> Description: USB 2.0 Hub
----> DeviceID: USB\VID_045B&PID_0209\5&30B7B990&0&9
----> Status: 0
--> USB 2.0 Hub
----> DeviceID: USB\VID_045B&PID_0209\5&30B7B990&0&10
----> Status: 0
----> Status: 0
----> DeviceID: USB\VID_1532&PID_0114\5&30B7B990&0&11
----> Status: 0
--> Synaptics USB Human Interface Device
----> Description: Synaptics USB Human Interface Device
----> Manufacturer: Synaptics
----> DeviceID: USB\VID_1532&PID_0114&MI_00\6&13EBF190&0&0000
----> Status: 0
--> Razer DeathStalker Ultimate
----> Description: Razer DeathStalker Ultimate
----> DeviceID: HID\VID_1532&PID_0114&MI_00\7&CEC0AA8&0&0000
----> Status: 0
----> DeviceID: USB\VID_1532&PID_0114&MI_01\6&13EBF190&0&0001
----> Status: 0
----> DeviceID: HID\VID_1532&PID_0114&MI_01&COL01\7&24AF96ED&0&0000
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_0114&MI_01&COL02\7&24AF96ED&0&0001
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_0114&MI_01&COL03\7&24AF96ED&0&0002
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_0114&MI_01&COL04\7&24AF96ED&0&0003
----> Status: 0
----> Service:
----> DeviceID: HID\VID_1532&PID_0114&MI_01&COL05\7&24AF96ED&0&0004
----> Status: 0
----> Service: rzjstk
----> DeviceID: {7315E94C-755A-4C6A-9200-6D833D940EEA}\HID_DEVICE&ID_0B\7&24AF96ED&0&11
----> Status: 0
--> HID-compliant game controller
----> Service:
----> Description: HID-compliant game controller
----> DeviceID: HID\VHIDJS\8&1B5A1BCD&0&0000
----> Status: 0
----> DeviceID: USB\VID_1532&PID_0114&MI_02\6&13EBF190&0&0002
----> Status: 0
----> DeviceID: HID\VID_1532&PID_0114&MI_02\7&D8592B&0&0000
----> Status: 0
----> Service: rzhnet
----> DeviceID: USB\VID_1532&PID_0114&MI_03\6&13EBF190&0&0003
----> Status: 0
--> USB Mass Storage Device
----> Service: USBSTOR
----> Description: USB Mass Storage Device
----> Manufacturer: Compatible USB storage device
----> DeviceID: USB\VID_058F&PID_6366\058F63666438
----> Status: 0
--> Multiple Card Reader USB Device
----> Service: disk
----> Description: Disk drive
----> Manufacturer: (Standard disk drives)
----> DeviceID: USBSTOR\DISK&VEN_MULTIPLE&PROD_CARD__READER&REV_1.00\058F63666438&0
----> Status: 0
--> USB 3.0 Hub
----> Description: USB 3.0 Hub
----> DeviceID: USB\VID_045B&PID_0210\5&30B7B990&0&20
----> Status: 0
--> USB 3.0 Hub
----> DeviceID: USB\VID_045B&PID_0210\5&30B7B990&0&21
----> Status: 0
Report generated OK
taco smush
Re: Energy saving mode and un usable screen.
Postby taco smush » Wed Oct 22, 2014 1:12 am
log from the software
10/21/2014 8:09:13 PM:Ping thread called ping to www.google.com answered timeout
10/21/2014 8:08:33 PM:Ping thread called ping to www.google.com answered timeout
10/21/2014 8:07:44 PM:Sensor NETActivityBox 1413513780.74277 does not use an advanced skin
10/21/2014 8:07:43 PM:Sensor GPUInfoBox 1413512093.40226 does not use an advanced skin
10/21/2014 8:07:43 PM:Sensor CPUInfoBox 1413512077.63536 does not use an advanced skin
10/21/2014 8:07:43 PM:LCDSys - Screen clear requested and done
10/21/2014 8:07:43 PM:All done, task finished
10/21/2014 8:07:43 PM:Done
10/21/2014 8:07:43 PM:Removing current elements from the window-control
10/21/2014 8:07:43 PM:Profile is Custom (new)
10/21/2014 8:07:43 PM:Re-Init LCD
10/21/2014 8:07:43 PM:Reload settings end
10/21/2014 8:07:43 PM:Culture Type is: 1
10/21/2014 8:07:43 PM:Reload General (3d-Render) Mark: [fps]
10/21/2014 8:07:43 PM:Reload General (3d-Render) Mark: [ping]
10/21/2014 8:07:43 PM:Reload General (3d-Render) Mark: [render]
10/21/2014 8:07:43 PM:Reload General (3d-Render) Mark: [time]
10/21/2014 8:07:43 PM:ReloadMarks - Ended
10/21/2014 8:07:43 PM:Network timer (up/down) enabled
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/intelcpu/0/temperature/4]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [APP:disk_read_D:]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/lpc/it8728f/temperature/1]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHMD:/nvidiagpu/0/temperature/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [NET:1_up]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [APP:disk_read_C:]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [APP:disk_write_D:]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/intelcpu/0/clock/1]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [NET:1_down]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/intelcpu/0/power/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/lpc/it8728f/temperature/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/intelcpu/0/load/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHM:/nvidiagpu/0/clock/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [OHMD:/nvidiagpu/0/load/0]
10/21/2014 8:07:43 PM:Reload LCDSys Mark: [APP:disk_write_C:]
10/21/2014 8:07:43 PM:1413513134.09278
10/21/2014 8:07:43 PM:1413513264.74426
10/21/2014 8:07:43 PM:Emptying all marks
10/21/2014 8:07:43 PM:ReloadMarks - Started
10/21/2014 8:07:43 PM:LCDSysinfo - Set brigthness to 108
10/21/2014 8:07:43 PM:Profiles lcdsys2 Load Ended
10/21/2014 8:07:43 PM:ReloadSettings - Profile OnWindows using: Default
10/21/2014 8:07:43 PM:Loading OnWindowsProfiles
10/21/2014 8:07:43 PM:Loading lcdsys2 GameProfiles
10/21/2014 8:07:43 PM:Profiles Load Ended
10/21/2014 8:07:43 PM:ReloadSettings - Profile OnWindows using: #1 -> new
10/21/2014 8:07:43 PM:Added profile for OW: new
10/21/2014 8:07:43 PM:Loading GameProfiles
10/21/2014 8:07:43 PM:Reload settings checkpoint 7
10/21/2014 8:07:43 PM:Reload settings checkpoint 6
10/21/2014 8:07:43 PM:Reload settings checkpoint 5
10/21/2014 8:07:43 PM:Reload settings checkpoint 4
10/21/2014 8:07:43 PM:Reload settings checkpoint 3
10/21/2014 8:07:43 PM:Reload settings checkpoint 2
10/21/2014 8:07:43 PM:LCDSys2 Cache is Enabled
10/21/2014 8:07:43 PM:LCDSys Cache is Enabled
10/21/2014 8:07:43 PM:Reload settings checkpoint 1
10/21/2014 8:07:43 PM:Reload settings started
10/21/2014 8:07:43 PM:Now reloading all the stored settings
10/21/2014 8:07:43 PM:Processed OK
10/21/2014 8:07:43 PM:Removing current elements from the window-panel
10/21/2014 8:07:43 PM:-> upload_sensor :
10/21/2014 8:07:43 PM:-> bg_box : 122
10/21/2014 8:07:43 PM:-> width : 148
10/21/2014 8:07:43 PM:-> p_downi : 10;10
10/21/2014 8:07:43 PM:-> disabled : Enabled
10/21/2014 8:07:43 PM:-> download_sensor :
10/21/2014 8:07:43 PM:-> index_value : 1413507366.81091
10/21/2014 8:07:43 PM:-> height : 58
10/21/2014 8:07:43 PM:-> p_up : 47;30
10/21/2014 8:07:43 PM:-> type : NETActivityBox
10/21/2014 8:07:43 PM:-> x : 164
10/21/2014 8:07:43 PM:-> advancedskin : 0
10/21/2014 8:07:43 PM:-> p_upi : 100;15
10/21/2014 8:07:43 PM:-> text : NETActivityBox
10/21/2014 8:07:43 PM:-> p_down : 35;10
10/21/2014 8:07:43 PM:-> y : 150
10/21/2014 8:07:43 PM:save element 1413507366.81091
10/21/2014 8:07:43 PM:-> text : PINGBox
10/21/2014 8:07:43 PM:-> type : PINGBox
10/21/2014 8:07:43 PM:-> index_value : 1413507368.75991
10/21/2014 8:07:43 PM: Cleared
taco smush
Postby taco smush » Wed Oct 22, 2014 1:28 am
This is what its supposed to look like.
Then i was able to track the log saying this right after this happened.
(10/21/2014 8:19:55 PM:Ping thread called ping to http://www.google.com answered timeout)
But the random text i was talking about is this.....
taco smush
Postby TheLaGmAn » Wed Oct 22, 2014 1:31 pm
Saving mode triggers when the display didnt have an update for over X amount of time.
If you add just a text to the screen it will eventually get on saving mode because the text didnt need any update.
So its either two things:
The sensors arent updating for some reason:
A) You have set a refresh rate speed of 4 seconds and every 4 seconds there arent updates, which is odd because you have the clock at the top, should change the seconds.
B) Your USB is malfunctioning and not sending the updates to the screen
The second thing where you see "partial writes" on the screen is because some items were requested to draw and overwritten the saving mode, which shouldnt of go into saving mode in the first place.
So lets look at some things:
1- How long until the dispaly goes into the saving mode? its always the same amount of time?
2- Can you post the GOverlay LOG when it happens?
3- Can you post a screen of the LCDSysInfo > Status tab when this happens?
4- Can you post a screen of the LCDSysInfo > Settings tab?
And we will see from there.
Postby fifacoinhuiy » Fri Oct 24, 2014 4:59 am
hi ,nice you
fifacoinhuiy
