Destination Number to upload custom icons
Postby vinsgosselin » Fri Oct 17, 2014 6:41 am
Hi! I was wondering... How do I know how much "blocks" my custom icons use? If I write for example "401.1.cpulogo.jpg" and that my file actually needed 2 blocks, what will happen?
vinsgosselin
Re: Destination Number to upload custom icons
Postby TheLaGmAn » Fri Oct 17, 2014 1:23 pm
Are you using the latest BETA? in the last version it shows you how many slots it will use, the second number IN THE FILE is actually just for visual reference for yourself
Postby vinsgosselin » Fri Oct 17, 2014 8:10 pm
Ho okay thank you. One last question. When I open my computer (Windows 8.1 X64), I always see the "baloon" in the notifications tray that says "GOverlay Running in Tray [...]" and I need to click on it or on the X to make the message dissapear. Is there a way to stop this message from appearing? I'm running version 1.4.1.18 Beta.
Thank you!
vinsgosselin
Postby TheLaGmAn » Sat Oct 18, 2014 4:11 pm
Are you sure it doesnt go away by itself? maybe wait a little longer?
I will add an option to disable the baloon later
Postby vinsgosselin » Sat Oct 18, 2014 11:09 pm
WOW! Thank you very much for that fast update with the option to disable it! It wasn't dissapearing except if I clicked on the X or in the balloon.
Thanks again!
vinsgosselin
