Only displays text, graphics 'garbled'
Postby Breadinator » Sun Apr 22, 2018 4:00 am
I just received my 2.8" LCD display. After working through the driver for Win10 64-bit., I got GOverlay to recognize it, I noticed that none of the graphical indicators (beyond the occasional icon) seem to work for the device. I can get text to display (i.e. I get "r" and "w" with the default overlay), but everything else is black/missing. I've tried re-uploading all of the images to the device just to see if it would help, but aside from changing my load screen, it doesn't seem to be working.
Any ideas out there? I'm really baffled by this.
Breadinator
Re: Only displays text, graphics 'garbled'
Postby TheLaGmAn » Mon Apr 23, 2018 9:05 pm
uhm, that is very strange.
no icon at all works?
any of the default icons, if you create a new blank profile and put it in, works?
Postby Breadinator » Tue Apr 24, 2018 12:53 am
Sadly, no. I can't get anything in a blank profile to work except the text. Even then, some of the fancier text elements look really off (i.e. the default Date widget looks skewed).
Breadinator
Postby TheLaGmAn » Wed Apr 25, 2018 12:55 pm
Can you check in the logs to see if there is any error message?
Also try a different cable and make sure you dont have any USB hub between the device and the computer, and also try to connect the unit to the back ports of your CPU, not the front
