Help, Windows 10 Kernal Securtiy Fail
Postby Digidreamer » Sat Apr 07, 2018 7:59 pm
Can anyone help??
After the Last Windows Update, i Keep getting BSOD everytime i boot up, Tried living with having to reboot every time I turn on.
Just done a complete Install, went well till i forced the LCDsysinfo Driver, then i get the BSOD with the Kernal Security Check Faliure (As Bofore), Just uninstalled the driver and it's cleared.
Using Windows 10 Pro 64Bit Version 1709 Build 16299.125 on a Panasonic CF-C1 Mk2 Toughbook
I Play games so it's useful to see the temps etc.
Any Help Welcome
Regards
Digidreamer
Re: Help, Windows 10 Kernal Securtiy Fail
Postby TheLaGmAn » Wed Apr 11, 2018 11:45 pm
uhm, weird, its not happening to me.
LCDSysInfo2.5'' or LcdSysInfo3.5''?
I attached the driver for the 3.5 with the newest driver library, try just in case
LCDSysInfo2.zip
(880.31 KiB) Downloaded 543 times
Postby Digidreamer » Tue Apr 17, 2018 2:56 pm
I'll give it a try, the 2.8in works fine as the vesion on 154.
The 164 Gui dosn't work for me unless i connect up to a monitor. looks like windows Clips it and takes away the Save/apply button, so could be a local issue.
I'll post back the resaults
Regards
Digidreamer
Postby TheLaGmAn » Tue Apr 17, 2018 3:02 pm
the driver i posted is for the 3.5'' display, you have this issue with the 2.8''?
The save button being clipped out is due to the resolution (too low), it requires a minimum of 750px height, so if you use 1024x768, if you have a big taskbar (as windows 10 has) the button might be behind it.
Postby Digidreamer » Thu Apr 19, 2018 8:34 pm
No go on the driver, BSoD back Kernal Security fail, then restart ok. next time shut down, reoccurs, crash, count to 100% then reboot ok.
the gui, all screens ok but the LCDsysinfo 3.5"tab goes right off the bottom of the screen 1280 x 800.
Graphics Intel HD 3000 driver ver 9.17.10.4459.
Regards
Digidreamer
Postby TheLaGmAn » Sat Apr 21, 2018 9:44 pm
does the issue happen with the 2.8 or 3.5?
When it happens, doesnt matter which version of goverlay you use?
Postby Digidreamer » Tue Apr 24, 2018 8:36 am
the 2.8 with the old GUI, 100% working,
it's the newer 3.5in with the newer gui giving me a head ache,
seems to work ok on my gaming PC, but failing on the laptop which i use most of the time, Both running latest update windows 10 pro 64 bit.
regards.
Digidreamer
Postby TheLaGmAn » Thu Apr 26, 2018 6:27 pm
so the issue is the laptop.
The driver works alright, it must be an issue with a driver or app you have running on the laptop itself. Do you have any antivirus?
