Just purchased, quick question
Postby comfarol » Mon Mar 19, 2018 2:10 pm
Hi all, Just purchased the LCDsysinfo for GOverlay v2.0, I haven't received it yet but just wanted to know if profiles can be made in Portrait or Vertical orientation? I plan to have it mounted inside my case and having it in that config would be sweet.
comfarol
Re: Just purchased, quick question
Postby TheLaGmAn » Fri Mar 23, 2018 2:21 pm
the fonts only support horizontal orientation, images and the rest you can make them look vertical if you need to
Postby comfarol » Mon Mar 26, 2018 3:28 am
Alright cheers for the reply. That's a shame but I look forward to playing around with it and seeing what I can come up with.
comfarol
Postby skyhigh24 » Wed Apr 25, 2018 10:43 am
Just use images for Numbers and rotate it. Then use the Image Graph. So you will be able to rotate the text or Numbers :)
skyhigh24
Postby chicky » Thu Jun 03, 2021 11:34 am
Hello developer, we suggest feature to rotate text, please?
I tried hours with portrait. But never good result without text in portrait.
Rotate text feature will make your product 100% more versatile. Thanks lot!
chicky
