lcd system info
lcd system info
Postby gtbsbr » Thu Sep 18, 2014 12:26 am
Anyone successfully installed drivers on a 64 bit operating system?.lcd system info cold tears
If so let me in on the secret.My goverlay model was a cinch.The driver install package has some convoluded read me file,but thats about all the support the manufacters are willing to give.You would figure the manufacturer would have a 64 bit driver package that doesnt need any modifying.Thanks for any info.
gtbsbr
Re: lcd system info
Postby TheLaGmAn » Fri Sep 26, 2014 9:35 pm
What do you mean?
Are you talking about the LCDSysInfo normal version? (this one doesnt work with GOverlay).
The GOverlay version, the driver works with x64 with no problem at all (i've been using it on W7 x64 and W8 x64 for a very long time) and the driver does not need any modification at all, just to disable driver signature as explained in the FAQ (by pressing a key) and on reboot you can install the driver normally.
If its not working for you as explained in the FAQ its most likely a conflic with your software, you should try on another computer.
