"Error Opening Device"
Re: "Error Opening Device"
Postby TheLaGmAn » Fri Dec 28, 2018 2:17 pm
Your device is not working in goverlay?
The message is for the lcdsysinfo 2.8'' (1.0), you can go to the lcdsysinfo 2.8 tab and in setting set it to disabled.
does the 3.5 (2.0) work if you go to the lcdsysinfo 3.5'' tab and set up a profile?
Postby ppgrainbow » Fri Dec 28, 2018 10:35 pm
TheLaGmAn wrote:Your device is not working in goverlay?
Thank you for the response. All I had to do was to disable LCDSysInfo 2.8" by going to > Settings > LCDSysInfo Enabled set it to Disabled and everything should be all good. :)
LCDSysInfo 3.%" works without any errors. :)
ppgrainbow
