"Error Opening Device"
Re: "Error Opening Device"
Postby Owtdemun » Wed Jun 20, 2018 4:16 pm
I´m experiencing the same issue :(
Here is the goverlay tester result:
Report generated at: 20/06/18 13:10:30 PM
------------- GOverlay Tester ------------
--> Version 0.5
--> Arguments :C:\Users\Nando\Downloads\GOverlay_Tester_v05\GOverlay_Tester.exe
------------- OS Info ------------
--> Version: 6.2.9200.0
--> Name: Microsoft Windows 10 Pro
--> Windows is 64 bits
------------- File Drivers Check ------------
System32 located at: C:\WINDOWS\system32\
LibUsb0.dll not found
drivers\libusb0.sys not found
------------- LibUsb Driver Status ------------
LibUsb Kernel version: 0.0.0.0
------------- Related Devices Connected ------------
--> LCDsysinfo (GOverlay)
----> Service: 0
----> Description: LCDsysinfo (GOverlay)
----> Manufacturer: 0
----> DeviceID: USB\VID_20A0&PID_41EC\LCDSZ
----> Status: 28
------------- Devices Detected ------------
------------- LibUsb Utility Devices Report ------------
------------- Listing all USB Connected Devices ------------
Strangely, my goverlay was working properly and now this happens.
Owtdemun
Postby TheLaGmAn » Wed Jun 20, 2018 4:20 pm
The tester shows that the driver is not properly installed (maybe an update to windows 10 that broke it)
Try to reinstall the driver.
Postby Thompson » Wed Jun 20, 2018 9:15 pm
TheLaGmAn wrote:try the new version of goverlay tester and post the results
http://goverlay.com/UserFiles/GOverlay/ ... er_v05.zip
Sorry to keep bothering you for no reason! I went ahead and simply re-installed the driver and now it is detected and working without any issues. It seems like, in one of the Windows 10 updates, it caused some issue with the driver. A 3 minute reinstall and I was good to go. Thanks for your help.
Thompson
Postby RayDog95 » Thu Jun 21, 2018 3:22 am
I have same issue, and what do you mean install driver. Doesn't it get installed when the screen is plugged in. I've turned that driver screening thing off and tried to install and restart several times and keep frustrating myself because I see the same anewer in the forums everywhere "just install the drivers" but it won't let me.
RayDog95
Postby DooMknight87 » Thu Jun 21, 2018 2:10 pm
RayDog95 wrote:I have same issue, and what do you mean install driver. Doesn't it get installed when the screen is plugged in. I've turned that driver screening thing off and tried to install and restart several times and keep frustrating myself because I see the same anewer in the forums everywhere "just install the drivers" but it won't let me.
Just go to the FAQ: http://www.goverlay.com/content/faq/
Here is a step by step guide for the driver installation in various SO (with images), this is from the windows 10 section:
How can i install the driver on Windows 10?
We provide the driver for "LCDSysInfo for GOverlay" bundled with GOverlay.
Here is how to install the driver on Windows 10, it requires disabling the digital signature and to do so, you will need to restart your computer.
Step 1: Connect 'LCDSysInfo for GOverlay'
Connect the Device, you will see windows detects it but won't be able to install the driver.
Save all your documents because you will have to restart your computer.
Move your mouse to the bottom-right edge of your screen and click on the notifications icon. Then click on All Settings
etc...
DooMknight87
Postby alavi » Mon Aug 13, 2018 8:21 pm
Hey Guys,
Hopefully someone can help me. I am using the 3.5" screen on Windows 10.
I installed GOverlay and then installed the drivers (as the installer explained the drivers need to be installed last). I installed them after turning off signatures and did so using http://zadig.akeo.ie/, which I found on viewtopic.php?f=2&t=308 (the regular install was not working for some reason).
I'm experiencing the same issues that the OP mentioned (enabled, not detecting), however, I am unable to adjust brightness.
The system settings show that it is not having any driver issues and I bought it from the eBay page that this site directed me to (so it's certainly compatible). I'm using an off-market USB cable, but the computer is able to recognize the device (I'm just not sure why the software can't).
Any ideas?
Thanks!
alavi
Postby TheLaGmAn » Wed Aug 29, 2018 3:32 pm
Can you post the results of the GOverlay Tester?
Postby comfarol » Wed Nov 28, 2018 9:40 am
i just reinstalled the drivers by disabling digital signatures and im getting this spam in the log too.
comfarol
Postby TheLaGmAn » Tue Dec 04, 2018 1:11 pm
what do you mean getting this spam in the log?
the "Error Opening Device" ?
Is the display working for you?
Postby ppgrainbow » Fri Dec 28, 2018 6:00 am
I just installed GOverlay 2.0 under Windows 8.1 Update 1. I have followed the correct instructions on how to install the driver under my currnet operating system. I managed to reboot by disabling the digital signature in order to get the driver working.
And in the logs, I keep getting LCDSysInfo - Error opening device every second. I used the current version of your Goverlay Tester and here are the results:
Report generated at: 2018/12/27 21:50:28
--> Version 0.5
--> Arguments :C:\GOverlay\GOverlay_Tester.exe
--> Name: Microsoft Windows 8.1 Pro
System32 located at: C:\Windows\system32\
LibUsb0.dll found
--> Version: 1.2.2.0
drivers\libusb0.sys found
LibUsb Kernel version: 1.2.2.0
--> LCDsysinfo (GOverlay) 2.0
----> Service: libusb0
----> Description: LCDsysinfo (GOverlay) 2.0
----> Manufacturer: Coldtears Electronics
----> DeviceID: USB\VID_20A0&PID_41ED\2CDSZ
----> Status: 0
Device: #0 (Coldtears Electronics - LCDsysinfo (GOverlay) 2.0)
-> Pid: 16877
-> Vid: 8352
-> Product: LCDsysinfo (GOverlay) 2.0
-> Manufacturer: coldtears electronics
-> SerialString: 2cdsz
-> Is Open: True
-> IsAlive: True
-> Name: LCDsysinfo (GOverlay) 2.0
-> Rev: 100
-> DeviceDesc: LCDsysinfo (GOverlay) 2.0
-> HardwareId: System.String[]
-> CompatibleIds: System.String[]
-> Class: libusb-win32 devices
-> ClassGuid: {eb781aaf-9c70-4523-a5df-642a87eca567}
-> Driver: {eb781aaf-9c70-4523-a5df-642a87eca567}\0000
-> Mfg: Coldtears Electronics
-> FriendlyName:
-> LocationInformation: Port_#0004.Hub_#0008
-> PhysicalDeviceObjectName: \Device\USBPDO-17
-> BusTypeGuid: 9d7debbc-c85d-11d1-9eb4-006008c3a19a
-> LegacyBusType: 15
-> BusNumber: 0
-> EnumeratorName: USB
-> Address: 4
-> UiNumber:
-> InstallState: 0
-> RemovalPolicy: 3
-> SymbolicName: \??\USB#VID_20A0&PID_41ED#2cdsz#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
-> Connection Tests:
----> Connection OK
----> Serial: 228103200667167841
----> FW Version: 218
----> Connection Try #2 Succeded
----> Connection Try #3 Succeded
----> Connection Try #4 Succeded
----> Errors: 0:
Dev #2: coldtears electronics - LCDsysinfo (GOverlay) 2.0 - Serial Number: 2cdsz
bLength:             18
bDescriptorType:     01h
bcdUSB:              0110h
bDeviceClass:        FFh
bDeviceSubClass:     00h
bDeviceProtocol:     00h
bMaxPacketSize0:     08h
idVendor:            20A0h
idProduct:           41EDh
bcdDevice:           0100h
iManufacturer:       1
iProduct:            2
iSerialNumber:       3
bNumConfigurations:  1
  wTotalLength:         18
  bNumInterfaces:       1
  bConfigurationValue:  1
  iConfiguration:       0
  bmAttributes:         80h
  MaxPower:             50
    bInterfaceNumber:   0
    bAlternateSetting:  0
    bNumEndpoints:      0
    bInterfaceClass:    0
    bInterfaceSubClass: 0
    bInterfaceProtocol: 0
    iInterface:         0
Should I re-install the driver by the way? If re-installing doesn't work, then there may be a problem with the drivers in this latest version of GOverlay. :p
ppgrainbow
PreviousNext
