"Error Opening Device"
Postby Thompson » Sat Oct 28, 2017 2:06 pm
EDIT: See my newest comment at the bottom of this thread for a return of this problem in June 2018.
Hello,
I'm trying to get my 3.5" display to work. I have GOverlay v1.6.4 and I have already installed the 3.5" drivers (I had to disable signature verification as per the FAQ).
However, when I load up GOverlay I get this error repeatedly:
10/28/2017 9:02:17 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:43 AM:LCDSysInfo - Init
10/28/2017 9:02:43 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:44 AM:LCDSysInfo - Init
10/28/2017 9:02:44 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:45 AM:LCDSysInfo - Init
10/28/2017 9:02:45 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:46 AM:LCDSysInfo - Init
10/28/2017 9:02:46 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:47 AM:LCDSysInfo - Init
10/28/2017 9:02:47 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:48 AM:LCDSysInfo - Init
10/28/2017 9:02:48 AM:LCDSysInfo - Error opening device
10/28/2017 9:02:49 AM:LCDSysInfo - Init
10/28/2017 9:02:49 AM:LCDSysInfo - Error opening device
In the GOverlay "Status" window, it says LCDSysInfo 3.5 is "Enabled" but "Not Detected"
My actual display is totally black with just the backlight on - I can actually adjust the backlight brightness under the Output-->LCDSysInfo 3.5"-->Settings-->LCD Brightness (up to 255) setting... so it seems like the display is connected properly, but some how the software isn't reading it completely.
Any advice on how to get this working?
Thanks.
Thompson
Re: "Error Opening Device"
Postby TheLaGmAn » Sat Oct 28, 2017 4:27 pm
Can you provide a screenshot of how it shows up in the device manager?
Also, try the report on the GOverlay tester
http://goverlay.com/UserFiles/GOverlay/ ... er_v03.zip
and post it here or send it by email to support@goverlay.com
Postby Thompson » Sun Oct 29, 2017 7:03 pm
TheLaGmAn wrote:Can you provide a screenshot of how it shows up in the device manager?
I ran the GOverlay tester and copied the results to a Pastebin link: https://pastebin.com/Jd8ZZXc6
Thompson
Postby TheLaGmAn » Tue Oct 31, 2017 4:16 pm
Everytihng seems fine in the logs.
In the lcdsysinfo 3.5 tab, does it show its enabled?
Postby Thompson » Thu Nov 02, 2017 1:56 am
TheLaGmAn wrote:Everytihng seems fine in the logs.
Here's what I am doing:
1) Open GOverlay v1.6.4
2) In the "Status" tab, it says "LCDSysInfo 3.5; Enabled; Not Detected"
3) In the "LCDSysInfo 3.5"" tab, under Statistics, it's all zeroes. No USB/Draw/Cache/Sensors/Render. Well, actually, the Sensors and Render will sometimes switch from zero to one then back to zero.
OH! I got it to work! I just realized... I never set a profile, so it was just on the Default, which was blank. Thanks anyway for all your help! Now I just need to figure out how to get my sensors from HWInfo64 to work and I'll be all set.
Thompson
Postby TheLaGmAn » Thu Nov 02, 2017 1:46 pm
Glad you got it to work, but, doesnt sound like a profile issue, if it said " not detected" on the lcdsysinfo 3.5 then the device was not being detected.
Now it says detected?
Postby demonclaw » Sun Dec 03, 2017 2:40 am
I'm having the same issue but I'm using the 2.8 screen.
demonclaw
Postby TheLaGmAn » Sun Dec 03, 2017 4:16 pm
have you properly installed the driver?
Postby Thompson » Wed Jun 20, 2018 10:29 am
Unfortunately, my error has returned. I had unplugged and not used the device for about 3-4 months, and upon plugging it back in, I am receiving the same "Error opening device" and "Init" spam errors in the log. The screen on my LCD display says "LCDsysinfo for GOverlay v2.0 run GOverlay for configuration" but I have the software open. In the bottom-right icon on my desktop, if I hover over the software icon, it says "GOverlay is not running"
Any advice would be really helpful.
Thompson
Postby TheLaGmAn » Wed Jun 20, 2018 1:16 pm
try the new version of goverlay tester and post the results
http://goverlay.com/UserFiles/GOverlay/ ... er_v05.zip
