More resistant case.....needed
Postby JPYZFR1 » Sun Jul 06, 2014 1:42 pm
After 4 months of using the micro usb female SMT Socket Connector broke by accident. I had bought a bottom angle micro usb cable http://www.ebay.com/itm/310712144379?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D310712144379%26_rdc%3D1 to avoid putting pressure on the connector.However using this cable, the connector broke.
Maybe a more resistant case will be appropriate to avoid such kind of damage.
Re: More resistant case.....needed
Postby TheLaGmAn » Tue Jul 08, 2014 10:27 pm
very strange, were you connecting and disconnecting it very often?
Postby JPYZFR1 » Tue Jul 15, 2014 5:45 pm
Not at all !!! But my wife is cleaning it very often..... :roll:
Postby LeChuck » Fri Aug 08, 2014 1:59 pm
One of the solder points of the microConnector is too small. Its breaks at all loads.
Cut your microCable and solder onto the onboard pins like picture below.
LeChuck
Postby gtbsbr » Thu Sep 18, 2014 12:34 am
Tell me about it.My usb connector that was soldered to board broke off.Gonna solder it on better to the new one I just got.Their workmanship is on par with their customer service.
gtbsbr
