Startup (RTSS_Hook.dll) error -_-
Postby tjs » Wed Jun 18, 2014 8:54 pm
When goverlay starts up in task scheduler i get error:
GOverlay is missing the needed files (RTSS_Hook.dll) to Work, Please Re-install the Application.
RTSS_Hook.dll is in the same folder, also i have tried updater, deleted folder and re downloaded replaced also downloaded latest beta.. still no change.
If task Scheduler is disabled or del. and GOverlay is in auto start it will still not run by itself, thats why i used task sch...
Also i can click on application or shortcut with no error and it works fine, its just on start up i get the error.
I have Files in c: > LCD > Goverlay>...
Pic attached
tjs
Re: Startup (RTSS_Hook.dll) error -_-
Postby TheLaGmAn » Wed Jun 18, 2014 8:56 pm
Hi tjs
what do you mean by
Are you using the option in GOverlay that says "autostart goverlay (windows vista and newer)"?
Postby tjs » Wed Jun 18, 2014 9:03 pm
TheLaGmAn wrote:Hi tjs
what do you mean by
I was using Autostart.
I have changed it to to start goverlay (windows vista and newer) and how it works
Thank you =)
tjs
Users browsing this forum: Google [Bot] and 2 guests
