Top Process sensor sometimes does not work
Postby DooMknight87 » Tue Feb 14, 2017 1:22 pm
It just stays at zero, restart the pc sometimes works, but it's a lottery...
What could be the problem?
DooMknight87
Re: Top Process sensor sometimes does not work
Postby TheLaGmAn » Tue Feb 14, 2017 2:28 pm
Check the GOverlay log shows any error.
Sometimes there is an error on windows that dont allow the queries to be made.
Also, just in case see if starting GOverlay as admin makes any difference.
Postby DooMknight87 » Tue Feb 14, 2017 2:51 pm
Actually im using GOvrlay as administrator, the log show this string all the time while using TOP PROCESS in the LCD:
14/02/2017 15:49:49:Error in processusage: Consulta no válida :: en System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
en System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
en GOverlay.Form1.v1()
DooMknight87
Postby TheLaGmAn » Tue Feb 14, 2017 4:25 pm
try open a CMD as administrator and write
lodctr /R
then reboot and see if it starts working
Postby DooMknight87 » Tue Feb 14, 2017 5:41 pm
TheLaGmAn wrote:try open a CMD as administrator and write
lodctr /R
Thank you!! It works properly now
EDIT: Bad news. After a few minutes the sensor get stucked and the same error starts appearing again in the log
DooMknight87
Postby TheLaGmAn » Tue Feb 14, 2017 6:14 pm
Its really strange, windows is disabling that data for some reason and thats why GOverlay cant read it.
What OS are you running?
Postby DooMknight87 » Tue Feb 14, 2017 8:51 pm
Yeah, windows at some moment stop sending info to the sensor. Really weird...
I'm using Windows 10 Pro 64bit with all updates availables at the moment
DooMknight87
Postby TheLaGmAn » Wed Feb 15, 2017 2:22 pm
if it happens again, while its happening, open powershell in windows (as admin) and type
Get-WmiObject -Query "Select Name,PercentProcessorTime,Timestamp_Sys100NS from Win32_PerfRawData_PerfProc_Process WHERE Name <> '_Total' and Name <> 'Idle'"
paste here what you get
Postby DooMknight87 » Wed Feb 15, 2017 4:48 pm
It's strange, when the error is occurring I get this
Get-WmiObject : Consulta no válida "Select Name,PercentProcessorTime,Timestamp_Sys100NS from
En línea: 1 Carácter: 5
+     Get-WmiObject -Query "Select Name,PercentProcessorTime,Timestamp_ ...
    + CategoryInfo          : InvalidArgument: (:) [Get-WmiObject], ManagementException
    + FullyQualifiedErrorId : GetWMIManagementException,Microsoft.PowerShell.Commands.GetWmiObjectCommand
But if I do before the error occurs, the code works correctly:
__GENUS              : 2
__CLASS              : Win32_PerfRawData_PerfProc_Process
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="System"
__PROPERTY_COUNT     : 3
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 62500000
Timestamp_Sys100NS   : 131316499089511293
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="smss"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 781250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="csrss"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 10156250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="wininit"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 312500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="csrss#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 9843750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="services"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 5000000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="lsass"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 5781250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 7500000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="winlogon"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 1093750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 9218750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#2"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#3"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 4375000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#4"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 3750000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="dwm"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 23906250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ekrn"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 81718750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#5"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 23125000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#6"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2031250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#7"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 8906250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#8"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 3906250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#9"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="spoolsv"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2968750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WUDFHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 0
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#10"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#11"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 468750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#12"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WUDFHost#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 156250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="eEBSvc"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="AsSysCtrlService"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#13"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 4531250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="atkexComSvc"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 9375000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="nvcontainer"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="IPROSetMonitor"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="nvwirelesscontroller"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="avgsvca"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 1875000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="dasHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#14"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#15"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 7656250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="NVDisplay.Container"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="NvTelemetryContainer"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="TuneUpUtilitiesService64"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 29687500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SearchIndexer"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 5625000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ScpService"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 5156250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SamsungRapidSvc"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ncs2prov"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiPrvSE"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2343750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiPrvSE#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2500000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="nvxdsync"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 17031250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="nvcontainer#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 22812500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="egui"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 4843750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="TuneUpUtilitiesApp64"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2187500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="sihost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="svchost#16"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="taskhostw"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 1406250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="GOverlay"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 46093750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ProcessGovernor"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ProcessLasso"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="explorer"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 21093750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="RuntimeBroker"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 7812500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="ShellExperienceHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 9687500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SearchUI"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 18906250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="audiodg"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SettingSyncHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="firefox"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 75156250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="backgroundTaskHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="aida64"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 40781250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="RtkNGUI64"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SamsungRapidApp"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="E_IATIIME"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="avguirna"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="avguix"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 2656250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="nvspcaps64"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SearchProtocolHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="SearchFilterHost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="NVIDIA Share"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 4062500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="NVIDIA Share#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="NVIDIA Web Helper"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
Name                 : NVIDIA Web Helper
PercentProcessorTime : 5468750
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="conhost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiPrvSE#2"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 20000000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiPrvSE#3"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 10937500
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiApSrv"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="WmiPrvSE#4"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="dllhost"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="dllhost#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="dllhost#2"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="powershell"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 3125000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__RELPATH            : Win32_PerfRawData_PerfProc_Process.Name="conhost#1"
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
PS C:\WINDOWS\system32>     Get-WmiObject -Query "Select Name,PercentProcessorTime,Timestamp_Sys100NS from Win32_P
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 63750000
Timestamp_Sys100NS   : 131316499140787976
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 10000000
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 24531250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PercentProcessorTime : 23281250
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
__GENUS              : 2
__SUPERCLASS         :
__DYNASTY            :
__DERIVATION         : {}
__SERVER             :
__NAMESPACE          :
__PATH               :
PSComputerName       :
DooMknight87
Postby TheLaGmAn » Wed Feb 15, 2017 5:03 pm
Yea, thats the issue that goverlay gets, at some point windows reports that the query is invalid.
Try this maybe?
https://support.solarwinds.com/Success_Center/Server_Application_Monitor_(SAM)/Windows_Service_Monitor_returns_'Invalid_Query'
1.Open an elevated CMD
2.Reregister the PerfMonCounters and WMI Classes.
a. Open an elevated CMD window on the target system.
b. Go to the following directory:
-c:\windows\sysWOW64\
c. Type the following commands:
lodctr /R
wmiadap.exe /f
If the WMI class is still missing, ensure that the following is not set and enabled in the registry:
KEY: “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\PerfProc\Performance”
Field: “Disable Performance Counters”
Value: 1
If the entry is found and the value set to 1, set it to 0 and reboot the system.
