.NET Runtime errors
.NET Runtime errors
Postby eric78 » Sun Jan 29, 2017 3:32 pm
Hi there
I'm getting strange .NET Runtime errors which usually end up,my GOverlay will switch off,my PC is turned on 24/7,usually around 5AM this is happening,I'm running too Aquasuite with GOverlay which is using or running .NET Runtime which can be culprit
Application: GOverlay.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.OutOfMemoryException
at System.String.InternalSubString(Int32, Int32)
at System.String.Substring(Int32, Int32)
at System.Windows.Forms.TextBoxBase.get_Lines()
at GOverlay.Form1.DebugLog(System.String)
at GOverlay.Form1.j()
at System.Threading.ThreadHelper.ThreadStart_Context(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Hope this helps
eric78
Re: .NET Runtime errors
Postby TheLaGmAn » Sun Jan 29, 2017 9:11 pm
Which GOverlay version are you using?
Postby eric78 » Wed Feb 01, 2017 11:25 am
Hi there
I'm using latest version GOverlay version 1.4.6,with previous versions I've never have issues
eric78
Postby TheLaGmAn » Wed Feb 01, 2017 4:10 pm
Can you try disabling the aquasuite plugin for a day and see if thats the issue?
Postby eric78 » Wed Feb 01, 2017 9:24 pm
TheLaGmAn wrote:Can you try disabling the aquasuite plugin for a day and see if thats the issue?
Hi there
I'm not running Aquasuite plugin for Goverlay , I'm running only Aquasuite SW, but I will do as you said will disable or will not run Aquasuite for one day
eric78
Postby eric78 » Wed Mar 15, 2017 3:37 am
Hi there
Sorry for late reply,but this does happen every day,GOverlay will switch off exactly same time around 5:30AM and I'm seeing not sure if its memory leak,but right now GOverlay is taking from my RAM 1,172,364K which is a lot there which this never happened previously with previous version of GOverlay there
eric78
Postby TheLaGmAn » Wed Mar 15, 2017 4:13 pm
Hi Eric,
Try the 1.5.0 version i just released.
I think that error should be fixed now (it was a memory leak with the audio sensor)
Postby eric78 » Thu Mar 16, 2017 1:44 am
TheLaGmAn wrote:Hi Eric,
Thanks for this
Will do few tests and let you know if this version will be better
Thanks again for swift update there
eric78
