DoLCDSys Exception at q.b()
Postby ZeZerT » Mon Jan 23, 2017 4:41 pm
Hello,
I've recently received my LCD screen, I installed the driver (for w10, latest version) as indicated in the FAQ. It all went good.
I have this error on start up : DoLCDSys Exception: Object reference not set to an instance of an object.: at q.b()
Full log here : http://paste.ofcode.org/wkWSLtjuHgDAXXixcUvs6s
When I launch the GOverlay software (latest version, 1.4.2) whether on admin or not, the LCD screen displays the welcome message "GOverlay now starting.." but then goes on energy saving mode because of the error.
What can I do to solve that please ?
Thanks in advance.
ZeZerT
Re: DoLCDSys Exception at q.b()
Postby TheLaGmAn » Mon Jan 23, 2017 5:16 pm
Could you send me an email to support@goverlay.com ? So we can do a teamviewer session to check it out so we can solve your issue.
Postby ZeZerT » Mon Jan 23, 2017 6:25 pm
I've sent you the mail :)
ZeZerT
Postby TheLaGmAn » Mon Jan 23, 2017 6:58 pm
Perfect, got it, check your spam folder just in case.
Postby tyf » Sat Jan 28, 2017 10:37 am
i have the same problem.
28/1/2017 12:34:52 μμ:Begining save
28/1/2017 12:34:52 μμ:Safe to save now
28/1/2017 12:34:52 μμ:Main config stored
28/1/2017 12:34:52 μμ:Object 0_lcdsys
28/1/2017 12:34:52 μμ:save element 1485599662,76159
28/1/2017 12:34:52 μμ:save element 1485599663,78672
28/1/2017 12:34:52 μμ:save element 1485599636,69036
28/1/2017 12:34:52 μμ:save element 1485599673,70771
28/1/2017 12:34:52 μμ:save element 1365543861.32573
28/1/2017 12:34:52 μμ:save element 1485599639,32434
28/1/2017 12:34:52 μμ:save element 1485599641,41169
28/1/2017 12:34:52 μμ:Removing current elements from the window-panel
28/1/2017 12:34:52 μμ:Removing current elements from the window-control
28/1/2017 12:34:52 μμ:Processed OK
28/1/2017 12:34:52 μμ:Object 3_arduino
28/1/2017 12:34:52 μμ:Object 222
28/1/2017 12:34:52 μμ:LCDSys Save Error - Object reference not set to an instance of an object.
28/1/2017 12:34:52 μμ:   at GOverlay.Form1.el(Object A_0, EventArgs A_1)
28/1/2017 12:34:53 μμ:DoLCDSys Exception: Object reference not set to an instance of an object.:   at ab.b()
tyf
Postby tyf » Sat Jan 28, 2017 10:07 pm
i got it working.
with the update and pickin my old profile i have error and i cant even set up a standar screen.
i dig up an old backup and it worked.
:roll:
tyf
Postby ZeZerT » Sun Jan 29, 2017 4:40 pm
He fixed it for me with teamviewer so I can't explain very well how :/ I saw it but I wouldn't be able to repeat or explain it
ZeZerT
Postby TheLaGmAn » Sun Jan 29, 2017 9:14 pm
If you are still having the issue or are able to reproduce it, contact me to support@goverlay.com so i can take a look to see if we can fix this bug.
Postby enderep12 » Thu Feb 02, 2017 9:21 pm
I have the same problem, only it says ab.b() instead of q.b().
Any advice on how to fix?
enderep12
