Startup screen and Goverlay vr charts
Postby JPYZFR1 » Sun Jan 22, 2017 9:49 am
GOverlay startup screen appears when alt+tab pressed. This was not happening with older updates.Maybe a "startup minimized" option in options menu solve the problem?
Also with alt+tab pressed a GOverlay VR charts running in background with GOverlay VR disabled from options menu.
Re: Startup screen and Goverlay vr charts
Postby TheLaGmAn » Sun Jan 22, 2017 8:12 pm
What do you mean with ALT+TAB pressed?
You are running goverlay.exe with ALT+TAB keys pressed?
Postby JPYZFR1 » Sun Jan 22, 2017 9:45 pm
No, I'm using alt+tab to change between programs and desktop.
Postby TheLaGmAn » Sun Jan 22, 2017 10:03 pm
got it, thank you.
I will upload a new version this week with the weather fix, this, and some other stuff.
Let me know if you find anything else.
Postby JPYZFR1 » Sun Jan 22, 2017 10:05 pm
Ok. Thanks
