Serial port listening application
Postby MegZamani » Fri Oct 14, 2016 6:58 pm
Hi all,
I have just ordered a LCD display for my new project. :-) just waiting.
My plan is to read live data from a Serial port (USB to RS232 / Com port3) and display the live data on the goverlay LCD display.
Has anyone done that before? - and it is possible? if yes how do i start the setup the goverlay software?
Thanks!
BG
Meg Zamani
MegZamani
Re: Serial port listening application
Postby TheLaGmAn » Fri Oct 14, 2016 7:43 pm
you should be able to do it with VB and the plugin system of GOverlay, so take a look into that, download the goverlay software and look at the plugins examples
