Screen is updating every 2 instead of 1 seconds
Postby mm1985 » Sat Jul 20, 2024 3:37 pm
At version 1.6.9.14 the screen is updated every 1 second as it should be.
But at version 1.6.9.19 (also in 1.6.9.18) the screen is only updated every 2 seconds.
Video 1.6.9.14 :
https://streamable.com/xspe83
Video 1.6.9.19:
https://streamable.com/wd99ue
You can see it in the clock in right top corner.
AMD Ryzen 9 7950X3D
ROG STRIX X670E-F GAMING WIFI
Windows 11 Pro 23H2
my profile (LCD2).gov
(274.11 KiB) Downloaded 5339 times
mm1985
Re: Screen is updating every 2 instead of 1 seconds
Postby TheLaGmAn » Sun Jul 21, 2024 4:09 pm
can you check on the lcdsysinfo status tab how long is taking the rendering and gathering of sensors? you can also post a screen here, because it could be that some sensors are taking longer to fetch forcing the screen to render slower
Postby mm1985 » Sun Jul 21, 2024 5:31 pm
mm1985
Postby TheLaGmAn » Sun Jul 21, 2024 6:45 pm
Postby mm1985 » Sun Jul 21, 2024 7:54 pm
Thanks, with the beta is works fine again.
mm1985
Postby nox420 » Thu Dec 19, 2024 1:59 pm
same fore me gonna try the beta
nox420
Postby robb » Sat Dec 21, 2024 12:08 pm
noticed the same thing too so gonna try the beta
Postby sausage » Thu Oct 02, 2025 11:57 am
same to me - beta works great
sausage
Postby tryout » Wed Feb 11, 2026 7:57 pm
same here
tryout
Postby tedharris600 » Sun Mar 15, 2026 6:10 am
tedharris600
Users browsing this forum: No registered users and 17 guests
