CPU Load value not correct
Postby kultakala » Wed Oct 04, 2023 4:34 pm
I use GOverlay for several years now, upgraded to LCDSysInfo2 last year and everything worked fine.
Now i have a new PC and a lot of sensors could not be read by OpenHardware Monitor so i installed the GOverlay Beta 1.6.9.19 and use Libre Hardware Monitor.
In the Montitor Application itself all sensors are displayed, i have all voltages, Clocks, Temperatures, etc.
And also the CPU Total Load is shown and similar to the values that are shown by Windows Task Manager or MSI Center.
But although GOverlay shows all other values correct, the CPU Total Load is way too low.
Most of the time it shows 0% while the actual value is 3 to 5 %.
With more load at about 15 % GOverlay shows 4% and with full load at 100% GOverlay shows only 35%.
My Processor is a AMD RX7900X3D.
As The Libre Monitor shows the correct values i assume GOverlay does something wrong or what could be the reason for that, any idea ?
Cheers,
kultakala
Re: CPU Load value not correct
Postby TheLaGmAn » Mon Oct 09, 2023 11:18 pm
There is an issue with LHM displaying wrong values for total cpu.
Which version of goverlay worked correctly? that version probably had an older LHM version without that bug
Postby kultakala » Wed Oct 18, 2023 10:52 am
But LHM itself shows me the correct values, only GOverlay shows much less cpu load.
On my old pc i used Open Hardware Monitor but it does not detect many of the sensors in my new pc.
kultakala
Postby TheLaGmAn » Tue Oct 24, 2023 8:55 pm
yes, the issue is on the library they provide, its not on their app.
we are talking about the sensors reported ad LHMD, not LHM, correct?
Postby kultakala » Wed Oct 25, 2023 6:54 am
I am using Libre Hardware Monitor, LHM ?
What do you mean by LHMD ?
kultakala
