Weather info not updating
Postby epicgamerlolilol » Fri Aug 04, 2023 11:50 am
Hello, I have a LCDSysinfo 3.5
Goverlay Version 1.6.9
Firmware 218
Windows 11
The weather icon and the temperature is not fetching any data, it was working fine until a Week ago.
Here is the log :
03/08/2023 12:35:38:WeatherPull (Global) - Thread ended
03/08/2023 12:35:38:WeatherPull (Global) - 1581871067,8869 : Exception thrown: La clé donnée était absente du dictionnaire. :: à Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
à Microsoft.VisualBasic.CompilerServices.NewLateBinding.CallMethod(Container BaseReference, String MethodName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, BindingFlags InvocationFlags, Boolean ReportErrors, ResolutionFailure& Failure)
à Microsoft.VisualBasic.CompilerServices.NewLateBinding.InternalLateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, ResolutionFailure& Failure, Boolean[] CopyBack)
à Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateInvokeDefault(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, Boolean[] CopyBack)
à Microsoft.VisualBasic.CompilerServices.NewLateBinding.InternalLateInvokeDefault(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, Boolean[] CopyBack)
à GOverlay.clsWeather.GetTemp()
à GOverlay.Form1.GLOBAL_weatherPull_Thread()
03/08/2023 12:35:38:WeatherPull (Global) - 1581871067,8869 : Fetching temperatures: city: 884 / C
03/08/2023 12:35:38:WeatherPull (Global) - 1581871067,8869 - City >Paris< found as 884 with location: 48.85717010498 , 2.3413999080658
03/08/2023 12:35:37:WeatherPull (Global) - 1581871067,8869 - has no govWid, getting one
03/08/2023 12:35:37:WeatherPull (Global) - 1581871067,8869 - investigating: Paris
03/08/2023 12:35:37:WeatherPull (Global) - 1581871067,8869 - is active on a profile, requested by 1581871067,8869
03/08/2023 12:35:37:WeatherPull (Global) - Getting weather info - 1 weathers
Any ideas how to fix it?
Thanks !
epicgamerlolilol
Re: Weather info not updating
Postby TheLaGmAn » Sun Aug 06, 2023 1:08 am
thank you for reporting, will take a look since we did some server changes, thats probably affecting
Postby TheLaGmAn » Sun Aug 06, 2023 1:21 am
can you check now?
Postby epicgamerlolilol » Sun Aug 06, 2023 1:29 pm
Hello, working all fine now! Thanks!
epicgamerlolilol
Users browsing this forum: Google [Bot] and 10 guests
