Sensor button
Sensor button
Postby Bagheera » Sun Oct 17, 2021 11:27 am
I've had the Goverlay for a long time now, and I've also created my own templates. But I always helped me to copy certain elements from existing tampletes and edit them according to my wishes.
But still have the following problem!
Which element do I have to choose here:
um zu diesem Ergebnis zu kommen:
I can't find an element on the right side where the entry "Sensor" is present.
Thank you very much for your help
Bagheera
Re: Sensor button
Postby TheLaGmAn » Mon Nov 08, 2021 9:57 pm
to add that type of element, just click on a SENSOR on your sensors list, it will add that type of element directly to the screen
