need stream infos about shoutcast from my radio and any info
Postby maxgamer2006 » Wed May 12, 2021 11:45 am
i have build themes self for my x300 build with 3400g and vega 11 but i missing my stream from my radio on display can the player build in display about song and title modi infos in the display (need for check modi send clean title name and song from aimp player) and network and ip display. i no finisch with the screen
or used the stream info from shoutcast v1 player
and 1 small bug i need the voltage info no 1 V better is 1,x volt or 0,x v how can fix it
and more ts infos no only talk see.
iam used most the aimp player..
hope understnad me what i mean
i from germany my english is no the best.. and on file see my first build with hwinfo setting
maxgamer2006
Re: need stream infos about shoutcast from my radio and any
Postby JaxyL_597 » Wed May 26, 2021 12:22 am
maxgamer2006 wrote:and 1 small bug i need the voltage info no 1 V better is 1,x volt or 0,x v how can fix it
Me too I'm interested to how to show the decimals on voltages
JaxyL_597
Postby TheLaGmAn » Mon May 31, 2021 1:26 pm
what sensor are you using for the voltage?
Users browsing this forum: No registered users and 13 guests
