aida 64 with go overlay please help
Postby peg1988 » Tue Apr 27, 2021 6:43 pm
Hello I hope I find help here.. I have tried the problem with aida 64 I have already tried it under the point > settings > external application, and selected the sensors. Unfortunately I miss the cpu temp sensor me it shows from aida 64 no sensors in go overlay. With HW info it works but this is not compatible with the i cue so all fans spin
peg1988
Re: aida 64 with go overlay please help
Postby TheLaGmAn » Wed Apr 28, 2021 1:12 am
you have the cpu temp sensor in AIDA?
Does goverlay show ANY other sensor? or is it just missing the cpu temp?
Postby peg1988 » Wed Apr 28, 2021 3:20 pm
on aida it Shows all sensors and on the overlay there is aida 64 but if i click on it there are no ssnsors shown up
peg1988
Postby TheLaGmAn » Thu Apr 29, 2021 2:06 pm
have you marked the option "enable writing sensor values to registry"?
Look at this screen
http://prntscr.com/129937x
Postby nikkdizzle » Sun Aug 01, 2021 8:32 pm
I'm having the same issue...any help with a resolution?
nikkdizzle
Postby TheLaGmAn » Mon Aug 02, 2021 5:47 pm
have you checked my screen? do u have it marked?
