HWInfo 7.00
HWInfo 7.00
Postby MrDanielVie » Tue Mar 09, 2021 3:34 pm
Do not install the new HWInfo 7.00. Goverlay does not work fully with HWInfo 7.00 (unless you have a pro license).
In the new free license from HWInfo, there is only 12 hours of shared memory support. After this period, this setting must be activated again manually in the HW info settings.
MrDanielVie
Re: HWInfo 7.00
Postby TheLaGmAn » Tue Mar 09, 2021 4:55 pm
You can still use HWiNFO 6.X with GOverlay as usual.
If you intend to use HWiNFO 7, it works with GOverlay but depends on your HWiNFO license.
If you use free license, you have to start HWiNFO in full mode, go to settings and enable shared memory support as the next image shows
http://prntscr.com/10ha3s3
After this, you still need to open the sensors tab, otherwise it will not send sensors info.
After you do this two steps, GOverlay will be able to read HWiNFO data from 12 hours straight, after that, you need to re-enable HWiNFO shared memory support
You can still use HWiNFO 7.X with GOverlay as you used to use it with 6.X.
Re: HWInfo 7.00
Postby Elric8/2 » Wed Apr 07, 2021 5:25 am
Is it fixed with 7.02 now?
Elric8/2
Re: HWInfo 7.00
Postby TheLaGmAn » Wed Apr 07, 2021 5:03 pm
there is nothing broken, its just the way hwinfo works now, you need a license if you are >=7.00 to use it as before, otherwise stay <7.00
Users browsing this forum: No registered users and 20 guests
