Import fulscreen Backround
Postby Sub200 » Tue Jan 05, 2021 3:12 pm
Englisch:
Hey
I got the display today and already created a complete background in Photoshop so that I can load it straight into it without having to create so many icons.
However, this image is not displayed to me when I select Backround Image.
So I saved the standard backgrounds and renamed the picture to "backround_2" and copied it to the folder "C: \ Program Files (x86) \ GOverlay \ LCDSysInfo2 \ default-files" but it is still not displayed.
Can you tell me what I'm doing wrong
Deutsch:
Hey,
ich habe heute das Display bekommen und schon in Photoshop einen kompletten Backround erstellt damit ich diesen gleich reinladen kann ohne so viele Icons erstellen zu müssen.
Allerdings wird mir bei der Auswahl Backround Image dieses Bild nicht angezeigt.
Also habe ich die standard Hintergründe weggesichert und das Bild ebenfalls auf "backround_2" umbenannt und in den Ordner "C:\Program Files (x86)\GOverlay\LCDSysInfo2\default-files" kopiert aber trotzdem wird mir dieser nicht angezeigt.
Könnt ihr mir sagen was ich falsch mache?
Sub200
Re: Import fulscreen Backround
Postby TheLaGmAn » Tue Jan 05, 2021 3:23 pm
You need to actually upload the file to the device.
go to lcdsysinfo 3.5 > upload > select files to upload and select the file.
Keep in mind it has to be BMP.
You could COPY one of the existing bmp background files and paste your image on it to mantain the same file and properties and then upload it as a new file
Postby Sub200 » Tue Jan 05, 2021 3:39 pm
Ah understand.
will test it right away when I get home from work;)
Sub200
Postby Sub200 » Tue Jan 05, 2021 3:50 pm
Perfect now i see what i want;).....
When iam finish with this profile i upload it;)
Sub200
Postby TheLaGmAn » Tue Jan 05, 2021 4:10 pm
awesome!
Postby Sub200 » Tue Jan 05, 2021 8:58 pm
So my first try;)
Template was Intel-Nvidia V1.0 from Sir_Coleslaw ;)
Sub200
Postby Sub200 » Tue Jan 05, 2021 10:47 pm
Now only the water block for my 3080 Suprim has to come and then it's done :)
Sub200
Postby TheLaGmAn » Wed Jan 06, 2021 8:13 pm
looks great!
