Weather not working
Re: Weather not working
Postby JPYZFR1 » Wed Feb 02, 2022 9:31 pm
Everything is working fine!!! Thanks
Postby JPYZFR1 » Thu Aug 03, 2023 7:13 pm
3/8/2023 22:09:06:WeatherPull (Global) - Thread ended
3/8/2023 22:09:06:WeatherPull (Global) - 1396888993.4503 : Exception thrown: The given key was not present in the dictionary. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.CallMethod(Container BaseReference, String MethodName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, BindingFlags InvocationFlags, Boolean ReportErrors, ResolutionFailure& Failure)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.InternalLateIndexGet(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, ResolutionFailure& Failure, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateInvokeDefault(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.InternalLateInvokeDefault(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean ReportErrors, Boolean[] CopyBack)
at GOverlay.clsWeather.GetTemp()
at GOverlay.Form1.GLOBAL_weatherPull_Thread()
3/8/2023 22:09:06:WeatherPull (Global) - 1396888993.4503 : Fetching temperatures: city: 2235 / C
3/8/2023 22:09:06:WeatherPull (Global) - 1396888993.4503 - City >piraeus,greece< found as 2235 with location: 37.942848205566 , 23.64720916748
3/8/2023 22:09:05:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
3/8/2023 22:09:05:WeatherPull (Global) - 1396888993.4503 - has no govWid, getting one
3/8/2023 22:09:05:WeatherPull (Global) - 1396888993.4503 - investigating: piraeus,greece
3/8/2023 22:09:05:WeatherPull (Global) - 1396888993.4503 - is active on a profile, requested by 1396888993.4503
3/8/2023 22:09:05:WeatherPull (Global) - Getting weather info - 1 weathers
3/8/2023 22:09:05:Calling WeatherPull
3/8/2023 22:09:05:Weather - Adding 1396888993.4503
Postby Nikan111 » Thu Aug 03, 2023 9:07 pm
Looking like Weather is not working for me either.
8/3/2023 1:58:00 PM:WeatherPull (Global) - Thread ended
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 : Exception thrown: The given key was not present in the dictionary. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
8/3/2023 1:58:00 PM:Sensor NETActivityBox 1587112054.32365 use an advanced skin
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 : Fetching temperatures: city: 51 / F
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 - City >Issaquah, WA, USA< found as 51 with location: 47.530090332031 , -122.03382110596
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 - has no govWid, getting one
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 - investigating: Issaquah, WA, USA
8/3/2023 1:58:00 PM:WeatherPull (Global) - 1587111557.81041 - is active on a profile, requested by 1587111557.81041
8/3/2023 1:58:00 PM:WeatherPull (Global) - Issaquah, wa : Exception thrown: The given key was not present in the dictionary. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
8/3/2023 1:58:00 PM:Sensor CPUInfoBox 1587111861.47811 does not use an advanced skin
8/3/2023 1:58:00 PM:WeatherPull (Global) - Issaquah, wa : Fetching temperatures: city: 51 / F
8/3/2023 1:58:00 PM:WeatherPull (Global) - Issaquah, wa - investigating: Issaquah, wa
8/3/2023 1:58:00 PM:WeatherPull (Global) - Issaquah, wa - is active on a profile, requested by 1618453087.52086
8/3/2023 1:58:00 PM:WeatherPull (Global) - issaquah, wa, usa - Ignoring since its not active on a profile, requested by 1587188972.31215
8/3/2023 1:58:00 PM:WeatherPull (Global) - Getting weather info - 3 weathers
8/3/2023 1:58:00 PM:Calling WeatherPull
8/3/2023 1:58:00 PM:Weather - Adding 1587111557.81041
8/3/2023 1:58:00 PM:LCDSys - Screen clear requested and done
8/3/2023 1:58:00 PM:ProcessWatch - Starts with parameters: "\Process(*)\% Processor Time" -si 1
8/3/2023 1:57:57 PM:Version detected 1.6.9 is the same as 1.6.9 - No need to update
8/3/2023 1:57:57 PM:Latest version received as: GOverlay_v169.zip (1.6.9)
8/3/2023 1:57:57 PM:GOverlay successfully inited
8/3/2023 1:57:57 PM:Loading charts
8/3/2023 1:57:57 PM:Loading GOverlay home page
8/3/2023 1:57:57 PM:Adding power mod events
8/3/2023 1:57:57 PM:Check Also Device FW Update2: 211991525075192354-217
8/3/2023 1:57:57 PM:Check Also Device FW Update: 2301021525516313710437-122
8/3/2023 1:57:57 PM:WeatherPull (Global) - Thread ended
8/3/2023 1:57:57 PM:WeatherPull (Global) - Issaquah, wa : Exception thrown: The given key was not present in the dictionary. :: at Microsoft.VisualBasic.CompilerServices.Symbols.Container.InvokeMethod(Method TargetProcedure, Object[] Arguments, Boolean[] CopyBack, BindingFlags Flags)
8/3/2023 1:57:57 PM:OHMD inited
8/3/2023 1:57:56 PM:WeatherPull (Global) - Issaquah, wa : Fetching temperatures: city: 51 / F
8/3/2023 1:57:56 PM:WeatherPull (Global) - Issaquah, wa - City >Issaquah, wa< found as 51 with location: 47.530090332031 , -122.03382110596
8/3/2023 1:57:56 PM:Req clear waiting 1
8/3/2023 1:57:56 PM:requesting Pm method create as cat: LogicalDisk instance: _Total counter: Disk Read Bytes/sec
8/3/2023 1:57:56 PM:requesting Pm method create as cat: LogicalDisk instance: _Total counter: Disk Write Bytes/sec
8/3/2023 1:57:56 PM:WeatherPull (Global) - Issaquah, wa - has no govWid, getting one
8/3/2023 1:57:56 PM: Cleared
Nikan111
Postby TheLaGmAn » Sun Aug 06, 2023 1:08 am
thank you for reporting, will take a look since we did some server changes, thats probably affecting
Postby TheLaGmAn » Sun Aug 06, 2023 1:21 am
can you check now?
Postby Nikan111 » Sun Aug 06, 2023 6:19 am
TheLaGmAn wrote:can you check now?
Working again for me.
Thanks! :D
Nikan111
Postby JPYZFR1 » Sun Aug 06, 2023 7:43 am
It's OK now. Thanks!!!
