Weather not working
Weather not working
Postby JPYZFR1 » Sat Dec 19, 2020 11:13 pm
Hi. Problem with weather?
20/12/2020 01:12:02:WeatherPull (Global) - Thread ended
20/12/2020 01:12:02:WeatherPull (Global) - Temperature is: 0 (0/0)
20/12/2020 01:12:00:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
20/12/2020 01:11:58:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
20/12/2020 01:11:56:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
20/12/2020 01:11:54:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
20/12/2020 01:11:52:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
20/12/2020 01:11:50:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
20/12/2020 01:11:50:WeatherPull (Global) - 1453575340.20227 - City >Greece,pireas< found as 2235 with location: 37.942848205566 , 23.64720916748
20/12/2020 01:11:50:WeatherPull (Global) - 1453575340.20227 - has no govWid, getting one
20/12/2020 01:11:50:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
20/12/2020 01:11:50:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
20/12/2020 01:11:50:WeatherPull (Global) - Getting weather info - 1 weathers
20/12/2020 01:11:50:Calling WeatherPull
Re: Weather not working
Postby TheLaGmAn » Sun Dec 20, 2020 12:22 am
its up now, thanks for the report
Postby JPYZFR1 » Sun Dec 20, 2020 8:21 pm
Hi. Yahoo weather shows cloudy and goverlay shows thunderstorms... :(
20/12/2020 22:00:28:WeatherPull (Global) - Thread ended
20/12/2020 22:00:28:WeatherPull (Global) - Temperature is: 0 (0/0)
20/12/2020 22:00:28:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
20/12/2020 22:00:26:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
20/12/2020 22:00:24:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
20/12/2020 22:00:22:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
20/12/2020 22:00:20:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
20/12/2020 22:00:17:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
20/12/2020 22:00:16:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
20/12/2020 22:00:16:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
20/12/2020 22:00:16:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
20/12/2020 22:00:16:WeatherPull (Global) - Getting weather info - 1 weathers
Postby TheLaGmAn » Mon Dec 21, 2020 1:16 pm
acording to that log it did not get the temp, but the service is up now.
its still not connecting to the service?
We are not using yahoo anymore, the yahoo message is old
Postby JPYZFR1 » Tue Dec 22, 2020 7:42 pm
Today still the same
22/12/2020 23:51:38:WeatherPull (Global) - Thread ended
22/12/2020 23:51:38:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 23:51:38:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
22/12/2020 23:51:36:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 23:51:34:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 23:51:31:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 23:51:29:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 23:51:27:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 23:51:24:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 23:51:24:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 23:51:24:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 23:51:24:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 23:51:23:Version detected 1.6.9.5 is the same as 1.6.9 - No need to update
22/12/2020 23:51:23:Latest version received as: GOverlay_v169.zip (1.6.9)
22/12/2020 23:51:21:Check Also Device FW Update: 21799805521914110238-117
22/12/2020 23:51:20:Checking for new version in method: Silent
22/12/2020 23:21:38:WeatherPull (Global) - Thread ended
22/12/2020 23:21:38:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 23:21:38:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
22/12/2020 23:21:35:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 23:21:33:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 23:21:31:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 23:21:29:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 23:21:26:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 23:21:24:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 23:21:24:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 23:21:24:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 23:21:24:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 22:51:38:WeatherPull (Global) - Thread ended
22/12/2020 22:51:38:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 22:51:38:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
22/12/2020 22:51:36:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 22:51:34:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 22:51:32:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 22:51:29:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 22:51:27:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 22:51:24:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 22:51:24:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 22:51:24:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 22:51:24:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 22:21:37:WeatherPull (Global) - Thread ended
22/12/2020 22:21:37:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 22:21:37:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
22/12/2020 22:21:35:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 22:21:33:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 22:21:31:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 22:21:28:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 22:21:26:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 22:21:24:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 22:21:24:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 22:21:24:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 22:21:24:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 21:51:37:WeatherPull (Global) - Thread ended
22/12/2020 21:51:37:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 21:51:37:WeatherPull (Global) - Temp value was not valid -Yahoo down?- So we are ignoring this update
22/12/2020 21:51:35:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 21:51:33:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 21:51:31:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 21:51:28:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 21:51:26:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 21:51:24:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 21:51:24:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 21:51:24:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 21:51:24:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 21:39:59:WeatherPull (Global) - Thread ended
22/12/2020 21:39:59:WeatherPull (Global) - Temperature is: 0 (0/0)
22/12/2020 21:39:57:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
22/12/2020 21:39:55:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
22/12/2020 21:39:53:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
22/12/2020 21:39:50:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
22/12/2020 21:39:48:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
22/12/2020 21:39:47:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
22/12/2020 21:39:47:WeatherPull (Global) - 1453575340.20227 - City >Greece,pireas< found as 2235 with location: 37.942848205566 , 23.64720916748
22/12/2020 21:39:46:WeatherPull (Global) - 1453575340.20227 - has no govWid, getting one
22/12/2020 21:39:46:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
22/12/2020 21:39:46:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
22/12/2020 21:39:46:WeatherPull (Global) - Getting weather info - 1 weathers
22/12/2020 21:39:46:Calling WeatherPull
Postby TheLaGmAn » Wed Dec 23, 2020 2:00 pm
its strange, i dont get those errors, its like a network connectivity issue, gonna send you a pm to check something
Postby JPYZFR1 » Wed Dec 23, 2020 7:31 pm
{"result":0,"error":"weather could not be fetched","details":null}
23/12/2020 21:28:57:WeatherPull (Global) - Thread ended
23/12/2020 21:28:57:WeatherPull (Global) - Temperature is: 0 (0/0)
23/12/2020 21:28:55:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 5 of 5)
23/12/2020 21:28:53:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
23/12/2020 21:28:51:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
23/12/2020 21:28:49:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
23/12/2020 21:28:47:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
23/12/2020 21:28:45:WeatherPull (Global) - 1453575340.20227 : Fetching temperatures: city: 2235 / C
23/12/2020 21:28:45:WeatherPull (Global) - 1453575340.20227 - City >Greece,pireas< found as 2235 with location: 37.942848205566 , 23.64720916748
23/12/2020 21:28:44:WeatherPull (Global) - 1453575340.20227 - has no govWid, getting one
23/12/2020 21:28:44:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
23/12/2020 21:28:44:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
23/12/2020 21:28:44:WeatherPull (Global) - Getting weather info - 1 weathers
23/12/2020 21:28:44:Calling WeatherPull
my internet connection is working fine
Postby JPYZFR1 » Sun Jan 16, 2022 9:56 am
Hi. Weather temp not working.
16/1/2022 11:50:58:WeatherPull (Global) - Thread ended
16/1/2022 11:50:58:WeatherPull (Global) - 1453575340.20227 : Cant fetch temperature, there is no govWid
16/1/2022 11:50:58:WeatherPull (Global) - 1453575340.20227 - City as >Greece,pireas< not found
16/1/2022 11:50:58:WeatherPull (Global) - 1453575340.20227 - has no govWid, getting one
16/1/2022 11:50:58:WeatherPull (Global) - 1453575340.20227 - investigating: Greece,pireas
16/1/2022 11:50:58:WeatherPull (Global) - 1453575340.20227 - is active on a profile, requested by 1453575340.20227
16/1/2022 11:50:58:WeatherPull (Global) - Getting weather info - 1 weathers
16/1/2022 11:50:58:Calling WeatherPull
Postby Nikan111 » Sun Jan 16, 2022 7:21 pm
Also getting the issues with weather:
1/16/2022 11:19:31 AM:WeatherPull (Global) - Thread ended
1/16/2022 11:19:31 AM:WeatherPull (Global) - 1587111557.81041 : Cant fetch temperature, there is no govWid
1/16/2022 11:19:31 AM:WeatherPull (Global) - 1587111557.81041 - has no govWid, getting one
1/16/2022 11:19:31 AM:WeatherPull (Global) - 1587111557.81041 - investigating: Issaquah, WA, USA
1/16/2022 11:19:31 AM:WeatherPull (Global) - 1587111557.81041 - is active on a profile, requested by 1587111557.81041
1/16/2022 11:19:31 AM:WeatherPull (Global) - Issaquah, wa : Cant fetch temperature, there is no govWid
1/16/2022 11:19:31 AM:WeatherPull (Global) - Issaquah, wa - City as >Issaquah, wa< not found
1/16/2022 11:19:31 AM:WeatherPull (Global) - Issaquah, wa - has no govWid, getting one
1/16/2022 11:19:31 AM:WeatherPull (Global) - Issaquah, wa - investigating: Issaquah, wa
1/16/2022 11:19:31 AM:WeatherPull (Global) - Issaquah, wa - is active on a profile, requested by 1618453087.52086
1/16/2022 11:19:31 AM:WeatherPull (Global) - issaquah, wa, usa - Ignoring since its not active on a profile, requested by 1587188972.31215
1/16/2022 11:19:31 AM:Weather - Adding Issaquah, wa
1/16/2022 11:19:31 AM:Weather - Adding issaquah, wa, usa
Nikan111
Postby TheLaGmAn » Sun Jan 30, 2022 2:30 pm
are you still getting this issues?
