Time: shadow remain after each minute, not readable
Postby THZ_BS » Wed Sep 02, 2020 3:56 pm
Hello
I have on my display the actual time "APP:hhmm-24". This works fine, but one minute later, for example when changing from 09:34 to 09:35, '09:34' remains as a shadow beneath '09:35', so the time isn't readable. How can I get rid of this?
And also - for the date, I have a window "2020-9-2" - even if I activate 'Show Zeros to fill" the date is displaye as 9-2 instead of 09-02. Can I change this?
THZ_BS
Re: Time: shadow remain after each minute, not readable
Postby TheLaGmAn » Wed Sep 02, 2020 6:07 pm
is this in the 2.8 display? are you using a non black background?
Postby THZ_BS » Wed Sep 02, 2020 9:22 pm
No, on the 3.5 with dark blue background
THZ_BS
Postby TheLaGmAn » Thu Sep 03, 2020 2:45 pm
Disable transparent BG on the element and set the background color of the element to dark blue
Postby THZ_BS » Thu Sep 03, 2020 3:44 pm
Many thanks - this helped!
THZ_BS
Users browsing this forum: Google [Bot] and 9 guests
