RTSS_hook.dll missing ?
Postby Elric8/2 » Thu May 21, 2020 11:38 am
Hello i have this error message since this morning, I reinstalled RTSS and goverlay but it did not worked.. What can i do?
https://zupimages.net/up/20/21/tijs.png
Elric8/2
Re: RTSS_hook.dll missing ?
Postby TheLaGmAn » Mon May 25, 2020 2:20 pm
What version of GOverlay are you using?
The message is because RTSS_hook.dll found in the GOverlay folder is missing or inaccesible.
1- Make sure the file exists in the GOverlay folder, if not, reinstall GOverlay or get it manually from the zip file
2- If the file is there, right click and properties and check that the file is not blocked
3- Make sure that if you are using a shortcut to the file, the shortcut path is the GOverlay folder
Users browsing this forum: No registered users and 31 guests
