Screen causing audio issue / freeze.
Postby Elric8/2 » Wed May 13, 2020 2:23 pm
Hi I have a steelserie wireless pro and the transmittor was plugued on a usb hub.
I tried to plug it directly on my PC but it gave some issues, sound was laggy, mouse froze.. I noticed the screen was resetting each time those freeze happened.
I tried to plug the lcdsysinfo on my GPU with a usb to usb C adaptor and it seems for now to do the trick but i found it very weird, what could be the issue?
Thanks for advices.
Elric8/2
Re: Screen causing audio issue / freeze.
Postby TheLaGmAn » Sun May 17, 2020 11:11 pm
Sounds like an issue with your USB controller, probably not giving enough power, you could try with a different port, front, back, different usb controllers.
using a usb hub is a bad idea because the device needs more power than the usb hub can give
Postby Elric8/2 » Mon May 18, 2020 4:58 am
Seems the actual culprit was the usb dongle of my mouse.. i changes the port and it seems ok but when it was plugued elsewhere, audio freeze and the sysledscreen restarted
Elric8/2
Users browsing this forum: No registered users and 35 guests
