NZXT Inaccurate Temp
Postby Scorpion69 » Mon Mar 16, 2020 9:50 pm
I never noticed this before until now....I have a NZXT Kraken X62 and the Temperature Sensor in NOT ACCURATE at all...I have it monitored from HWiNFO
I checked the Temperature in the NZXT Application and it showed 108 F as I expected ( I was running a high load) but the NZXT Sensor under HWiNFO (that is the only place that has it) is just NOT ACCURATE....it showed 93 F all the time
Do you have any suggestiuons?
Scorpion69
Re: NZXT Inaccurate Temp
Postby TheLaGmAn » Tue Mar 17, 2020 6:10 pm
could be an issue with HWiNFO , can you check LHM in the new beta to see if you have that sensor?
Postby Scorpion69 » Fri Mar 20, 2020 8:11 pm
Hi..
There are no Temp/Fan Speed sensors in LHM for the NZXT products
Scorpion69
Users browsing this forum: Google [Bot] and 3 guests
