teamspeak Talker
teamspeak Talker
Postby JPYZFR1 » Sun Feb 21, 2016 6:53 pm
Hi again.
Teamspeak Talker doesn't support Greek characters and shows question marks. Is there any way to use Greek characters?
Re: teamspeak Talker
Postby TheLaGmAn » Sun Feb 21, 2016 7:01 pm
The display doesnt support non-latin characters so there is no way to show me
Postby JPYZFR1 » Sun Feb 21, 2016 7:05 pm
Ok. Thanks.
Postby JPYZFR1 » Fri Jan 27, 2017 5:36 pm
27-Jan-17 19:30:14:TeamSpeak - Connected!
27-Jan-17 19:30:14:WhoAmI resolved as: 56 data was: clid=56 cid=90800
27-Jan-17 19:30:12:Teamspeak - Trying to connect to TS Telnet
27-Jan-17 19:17:58:WeatherPull (Global) - Thread ended
27-Jan-17 19:17:58:WeatherPull (Global) - Temperature is: 7 (7/36)
27-Jan-17 19:17:57:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
27-Jan-17 19:17:51:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
27-Jan-17 19:17:51:WeatherPull (Global) - investigating: pireas,gr
27-Jan-17 19:17:51:WeatherPull (Global) - Getting weather info
New versions seems to have a delay about 10 minutes to connect to teamspeak. Why is this happening?
Postby TheLaGmAn » Fri Jan 27, 2017 7:10 pm
The TS connection starts around 10 seconds after the TS app opens, so that log should be after you started the app, it wont appear if TS isnt running even if GOverlay is running.
Wasnt that the case?
Postby JPYZFR1 » Sat Jan 28, 2017 9:42 am
I will keep checking and I will sent you again.
Postby JPYZFR1 » Sun Jan 29, 2017 9:03 am
29-Jan-17 10:39:06:TeamSpeak - Connected!
29-Jan-17 10:39:06:WhoAmI resolved as: 50 data was: clid=50 cid=90784
29-Jan-17 10:39:04:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 10:37:49:WeatherPull (Global) - Thread ended
29-Jan-17 10:37:49:WeatherPull (Global) - Temperature is: 2 (2/33)
29-Jan-17 10:37:45:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 4 of 5)
29-Jan-17 10:37:40:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 3 of 5)
29-Jan-17 10:37:35:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 2 of 5)
29-Jan-17 10:37:30:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
29-Jan-17 10:37:24:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
29-Jan-17 10:37:24:WeatherPull (Global) - investigating: pireas,gr
29-Jan-17 10:37:24:WeatherPull (Global) - Getting weather info
29-Jan-17 10:07:58:WeatherPull (Global) - Thread ended
29-Jan-17 10:07:58:WeatherPull (Global) - Temperature is: 2 (2/33)
29-Jan-17 10:07:57:WeatherPull (Global) - Error getting temperature -Yahoo down?- Trying again (try 1 of 5)
29-Jan-17 10:07:51:Version detected 1.4.6 is the same as 1.4.6 - No need to update
29-Jan-17 10:07:51:Latest version received as: GOverlay_v146.zip (1.4.6)
29-Jan-17 10:07:51:WeatherPull (Global) - pireas,gr : Fetching temperatures: 959973 / C
29-Jan-17 10:07:51:WeatherPull (Global) - City >pireas,gr< found as 959973
29-Jan-17 10:07:51:OHMD inited
29-Jan-17 10:07:49:WeatherPull (Global) - pireas,gr has no WOEID, getting one
29-Jan-17 10:07:49:WeatherPull (Global) - investigating: pireas,gr
29-Jan-17 10:07:49:WeatherPull (Global) - Getting weather info
29-Jan-17 10:07:49:Calling WeatherPull
I run Teamspeak at 10:36:12 and goverlay didn't connect.
However it connected at 10:39:04 (3 minutes later) when i opened the goverlay application (right click on systray icon --> show --> log ) to see the log file.
When i sent you (New versions seems to have a delay about 10 minutes to connect to teamspeak) the same thing happened
The problem happens when i start TS for first time. After a successful connection between TS and Goverlay (by the way described above) every time i restart TS, the connection is instant.
Postby TheLaGmAn » Sun Jan 29, 2017 9:07 pm
Okay, i think i found the issue.
Please check if keeping the GOverlay window open (do not minimize it) the detection works fine all the time.
Postby JPYZFR1 » Sun Jan 29, 2017 9:18 pm
29-Jan-17 23:19:28:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
29-Jan-17 23:19:27:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 23:19:24:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
29-Jan-17 23:19:23:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 23:19:20:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
29-Jan-17 23:19:19:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 23:19:16:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
29-Jan-17 23:19:15:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 23:19:12:TeamSpeak - Connection exception: No connection could be made because the target machine actively refused it 127.0.0.1:25639
29-Jan-17 23:19:11:Teamspeak - Trying to connect to TS Telnet
29-Jan-17 23:19:11:TeamSpeak - Handle Incoming Exception: Index and length must refer to a location within the string.
Parameter name: length: at System.String.Substring(Int32 startIndex, Int32 length)
at t.c(IAsyncResult A_0)
The same happens when i close TS, the goverlay doesn't disconnect until i open the goverlay window.
And finally all working ok only when goverlay window is open.
Postby TheLaGmAn » Sun Jan 29, 2017 9:39 pm
Perfect, thats the issue, give me a couple of days and i will release that fix along with some others.
