HwInfo wont load and PingBox missing
Postby tbmalm » Sun Nov 01, 2015 12:00 pm
i had to rebuild my system and lost my goverlay profile.
as i built a new one, i discovered that the HwInfo now has a plug in. (thank you)
however, i got it to load its sensor values once. i have been unable to consistently get them to appear in design mode. they seem to magically appear in run mode.
can you provide some insight?
also, i was having trouble getting the ping box to accurately show the ping value. i deleted it, and it appears to no longer be part of the supplied values?
tbmalm
Re: HwInfo wont load and PingBox missing
Postby TheLaGmAn » Sun Nov 01, 2015 1:32 pm
What do you mean to get them to appear in design mode? it usually loads the values once they are used (saved) and not while adding them, so there are less resources used, but once you hit save that value will be showing.
About the pingbox, it should be there, and the accuracy it depends on where you are pinging, by default, it pings to www.google.com but you can change that in "Sensors > Latency"
