Terminator 2 themed profile.
I struggle a little to expose some sensors on my system (network ping being one) so these are from a variety of sources AIDA64, internal and OpenHW.
Uses the following 2 free fonts:
For the terminal text - https://fontsource.org/fonts/vt323
For the Cyberdyne text - https://www.1001freefonts.com/cyberdyne.font
Still wondering re white text or larger text, perhaps depends on how close your screen is.
For accuracy, this should be white text (as seen as the overlay from the T-800's inbuilt terminal) but green sells the 'computer inside the terminator's skull' better.
The text in the corner is just some of the system output from the Apple II they used to generate the T-800's terminal overlay seen in the film.
Update: Added date and time
