[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 502: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 379: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4752: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4754: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4755: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4756: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3887)
GOverlay Forum • View topic - Jon-PipBoy: 2024-08-09
Profiles shared thru the GOverlay Web Portal for GOverlay Plus
Postby jon.191023 » Sun Feb 11, 2024 10:21 pm
It's my Pipboy interface from LCDsysinfo readapted for the new goverlay device 7.8 with more details and informations thanks to a bigger screen and more available space.
You can also find my original profile on the Goverlay dedicated section :
viewtopic.php?f=6&t=2018
There is a lot of pictures you will have to modify for you config :
SSD,CPU,GPU & Memory brands
List of sensors used :
Volume detection : 3 modules
Date & Day Name : 2 modules
Clock : 1 module
Ping : 3 modules
Public IP : 2 modules
SSD Loads : 2 modules
SSD Temp : 2 modules
GPU Core Temp : 2 modules
GPU Hotspot temp : 2 modules
GPU delta temp (Hotspot/Core) : 2 modules
GPU Memory Used : 1 module
GPU Fan : 2 modules
CPU Core Temp : 2 modules
CPU Fan : 2 modules
Chassis Fan : 2 modules
RAM used : 1 module
IMPORTANT : For using the IP sensor, you will need to get the Beta Version of the desktop app : 2.0.24 because that one isn't implemented yet by default.
Proceed like this for get it :
1. Go to GOverlay and enter in the "Whats New" TAB
2. At the bottom-right, hit on the button "REQUEST BETA"
3. Enter the following CODE : "2.0.24_lqx"
The sensor will be available in your selection after update (Internal category)
I hope you gonna enjoy it. Feel free to work around it for custom your own pipboy & upload it here later.
Thx a lot to the Goverlay team for this amazing device and platform.
Update 15/02/24 :
-Titles with new font : Overseer (Big thx to Goverlay Team)
-Design modifications
-Pictures Resized
-Sensors reconfigured
-Colors modifications
-GPU & CPU Fan Sensors with icons
Update 17/02/24 :
-Fonts modification & new font added : monofonto
-Design modifications & corrections
-New sensors added : Signal Icon, Public IP detection, VPN detection Icon (you must fill a specific field in visual script from the sensor for that)
Update 23/02/2024 :
-Sensors thresholds corrections
-Pictures modifications for better reflect configuration
Update 09/08/2024
-All Fan sensors icons are now animated with various speeds and colors depending of thresholds
-Chassis fan sensor added
-Due to hardware upgrade, the GPU memory temp sensor has been replaced because that one isn't very present on many configurations from Librehardware library. It's now replace by the Hostpot sensor with additional implementation of delta temp sensor for better monitoring of thermal paste efficiency.
jon.191023
Re: Jon-PipBoy: 2024-02-11
Postby TheLaGmAn » Sun Feb 11, 2024 11:18 pm
hey, wish you would of tell me about the font, i would of made your life easier by adding it!
I added it, you have it at the end of the list, so you can replace all those images
Postby TheLaGmAn » Sun Feb 11, 2024 11:27 pm
i also recommend you re-upload the two images of the SSD with a much lower resolution, something like 200 pixels wide, right now its 1500 pixels wide and 600kb, it will slowdown the device having to have that image rendering even if its static, due to the resize it has to do while rendering every frame of the profile.
Samae with the mem, cpu and pip boy.
BTW, awesome profile, thanks for sharing!
Postby jon.191023 » Tue Feb 13, 2024 12:50 am
jon.191023
Postby jon.191023 » Tue Feb 13, 2024 12:52 am
jon.191023
Re: Jon-PipBoy: 2024-02-13
Postby Clone003 » Wed Feb 14, 2024 3:30 am
Nice profile!
Lots of info, but not too crowded imo
Clone003
Return to Shared Profiles
