Goverlay plus emulating a Bus stop real time arrival LCD at TST using Visual Scripting (VS) and Javascript Code in webapp. Webapp JSON element fetch API from bus serverthen use VS/JS to calculate the time difference between ETA and time now and display to the unit. When the arrival time is less than 1 minusing the changing element properties function to change the text to "Arriving". Can use the profile as a reference point to start VS/JS coding
