Startup: failed to connect socket please check credentials
Postby Azyate » Sun Apr 28, 2024 1:06 pm
when I start my GoverlayPlus, I get an error "failed to connect socket please check credentials".
It remains on the white screen with the Goverlay logo where the profile usually loads.
Azyate
Re: Startup: failed to connect socket please check credentia
Postby altanoruc » Sun Apr 28, 2024 2:07 pm
same problem here...
altanoruc
Postby jon.191023 » Sun Apr 28, 2024 2:45 pm
Same problem here.
Started today. No modifications made from my side.
jon.191023
Postby kbuchwitz » Sun Apr 28, 2024 5:45 pm
Same Problem
kbuchwitz
Postby Linuxer » Sun Apr 28, 2024 7:59 pm
Same here :-(
Michael
Linuxer
Postby hartmutenton » Mon Apr 29, 2024 12:35 am
Same :shock: Is this the end of GOverlay Plus :?:
hartmutenton
Postby TheLaGmAn » Mon Apr 29, 2024 1:23 pm
apologies about the delay, investingating the issue so it doesnt happen again and will resume the service soon
Postby TheLaGmAn » Mon Apr 29, 2024 1:42 pm
issue is fixed and took measures so it doesnt happen again (hopefully).
the issue was due to a certificate renewal and it will renew again on july 7, will keep an eye on that date to ensure the fix works correctly for that date.
very sorry about the delay!
Postby jon.191023 » Mon Apr 29, 2024 2:01 pm
My device still doesn't connect. It's sill displaying "failed to connect to socket. Please check credentials". Reboot doesn't change anything.
However my Goverlay app has reconnected now.
jon.191023
Postby TheLaGmAn » Mon Apr 29, 2024 2:30 pm
i see your device as connected, its still not working for you?
