Request: Vertical Text
Postby graham.ferguson9 » Tue Apr 02, 2024 9:18 am
Hi
Working on a profile that will use vertical elements.
Rather than build my text like this by adding individual characters and rotating each one:
R
A
M
Is it possible to rotate the entire word to flow vertically?
Also, for sensors using text output ie ram usage 24 Gb - how difficult would it be to make the text/numeric values follow a similar pattern?
Final question - is it possible to add a drop shadow or bloom?
Screenshot to illustrate the concept I'm working on below which might make sense of the request! Also I've got an idea for making a cityscape like Night City or LA from Blade Runner, using the billboards and buildings to display values, some of which will likely need to be vertical.
test matrix rain
If these things are an absolute pain to add then I can probably do a lot of it as part of the background, though that won't allow for customization. That said, no idea if my weird ideas are any good anyway, just having fun exploring. :D
graham.ferguson9
Re: Request: Vertical Text
Postby TheLaGmAn » Mon Apr 08, 2024 2:03 pm
Postby graham.ferguson9 » Wed Apr 10, 2024 8:30 pm
I'll give that a try, cheers for the help! :)
graham.ferguson9
Postby graham.ferguson9 » Sat Apr 20, 2024 10:10 am
Text is going to be too small with this layout.
I'll maybe try doing just "Matrix rain" zoomed in a bit.
graham.ferguson9
Postby graham.ferguson9 » Sat Apr 20, 2024 10:53 am
Still not convinced this one is easily realised.
WIP:
Layout is not as squashed on the device, but the stats might not stand out enough.
graham.ferguson9
