Screen Rotation
Screen Rotation
Postby graham.ferguson9 » Sat Mar 23, 2024 8:29 pm
Can you rotate the screen 180 deg?
Mine is currently upside down - relative to the expected case and stand orientation.
Thanks.
graham.ferguson9
Re: Screen Rotation
Postby TheLaGmAn » Sat Mar 23, 2024 9:28 pm
what do you mean upside down?
isnt the power cable on the left side?
Re: Screen Rotation
Postby graham.ferguson9 » Sat Mar 23, 2024 10:48 pm
It is on the right looking at the back of the device
graham.ferguson9
Re: Screen Rotation
Postby TheLaGmAn » Sun Mar 24, 2024 12:52 am
Re: Screen Rotation
Postby coldtearselectronics » Sun Mar 24, 2024 4:16 am
At the default orientation, the power cable is on the LEFT side when viewed from the front, in your case you may attached the stand wrongly, please turn your stand 180degree and attach it.
If you really need to have your power cable on the RIGHT side when viewed from the front, you can also do it in an easier way.
Plug in a USB mouse, then settings, advanced WIFI connection. It will open an android WIFI settings menu. click back (top left corner), then Display> Advanced> Display Rotation>
Change it to 270degree (90degree to default orientation)
Then press YES ( the button on the right side) to restart the device.
Note: the D-pad button will be inverted in this case
Re: Screen Rotation
Postby graham.ferguson9 » Sun Mar 24, 2024 5:26 pm
Cool, the stand is in the correct orientation. I may have misread the instructions which suggested that both screw holes would be visible through the slot of the stand.
All good, thanks for confirming. :)
graham.ferguson9
Re: Screen Rotation
Postby graham.ferguson9 » Sun Mar 31, 2024 2:44 pm
Just by way of explanation, I had misread the instructions and fitted the stand upside down. :oops:
Some days my brain loves to mess with me. :o
graham.ferguson9
