Picture Resolution
Picture Resolution
Postby Mikekastner205 » Wed Feb 14, 2024 7:45 pm
Hello, what maximum resolution can the images have for the profile? Thanks
Mikekastner205
Re: Picture Resolution
Postby TheLaGmAn » Wed Feb 14, 2024 8:20 pm
you mean for images used in the profile?
up to 1280x400 which is the device resolution, bigger than that wouldnt ever be needed and the bigger the image the bigger the impact on the rendering (even if you resize it on the element itself)
Postby Mikekastner205 » Thu Feb 15, 2024 6:42 am
Super thank you. However, I have pictures with a resolution of 200 x 229 and it simply doesn't want to take them. Now I'm confused and don't know what to do next. :(
Mikekastner205
Postby TheLaGmAn » Thu Feb 15, 2024 1:43 pm
thats odd, can you attach me the image so i can check if its an issue with that specific image?
Postby Mikekastner205 » Thu Feb 15, 2024 3:33 pm
I hope I attached it correctly.
Mikekastner205
Postby TheLaGmAn » Thu Feb 15, 2024 3:42 pm
i was able to add the image correctly.
what error are you getting?
Postby Mikekastner205 » Thu Feb 15, 2024 4:31 pm
I don't get any error message. I can add it to the other images, but when I try to select it, only a small red triangle appears at the bottom and it is not selected.
Mikekastner205
Postby Mikekastner205 » Thu Feb 15, 2024 4:34 pm
strange, now I don't have a red triangle.
Mikekastner205
Postby TheLaGmAn » Thu Feb 15, 2024 4:58 pm
thanks for reporting it, i found an issue related to that, should be fixed.
just in case do a hard refresh of the page (ctrl+f5)
Postby Lovermanmo01 » Thu Feb 15, 2024 6:30 pm
perfect, now it works. Thank you :)
Lovermanmo01
