Flickering icon sensor
Postby jon.191023 » Sun Feb 11, 2024 11:14 pm
I would like to report a visual anomaly on my device concerning the icon sensor element.
The icon flickering on every actualization data on my device. It always the case whatever the sensor used.
This problem is more visible when fast refresh is on in LAN mode.
jon.191023
Re: Flickering icon sensor
Postby TheLaGmAn » Sun Feb 11, 2024 11:18 pm
i will take a look, this happens even when the icon doesnt change?
Postby TheLaGmAn » Sun Feb 11, 2024 11:23 pm
i think i see the issue.
Give it a try now, you will need the profile to be re-loaded in the screen or if it still doesnt work, do a reboot of the unit.
Postby jon.191023 » Sun Feb 11, 2024 11:27 pm
jon.191023
Postby jon.191023 » Sun Feb 11, 2024 11:28 pm
jon.191023
Postby TheLaGmAn » Sun Feb 11, 2024 11:32 pm
great, added some comments on the profile post about the font and a request to make the images files smaller in resolution since big images slowdown the device on rendering
