Problem with import profil option
Postby jon.191023 » Sun Feb 11, 2024 1:54 am
I got a Problem.
A profile i backed up recently doesn't load during importation.
There is is no preview after i selected the file & it still display a blackscreen.
Nothing appear & there is no element on screen but the profile file is about 3.33 MiB and seems correctly saved when I'm opening him on Notepad.
Could you help me on that case please ?
I can send a copy of the profile i saved.
jon.191023
Re: Problem with import profil option
Postby jon.191023 » Sun Feb 11, 2024 2:37 am
Update :
When I'm inspecting the Console after i selected the profile for importation i got an network error concerning the preview loading with Error 400 "Invalid file"
I attached a screenshot of the error.
I don't know if it could help but just in case...
jon.191023
Postby TheLaGmAn » Sun Feb 11, 2024 9:35 pm
Thanks for reporting the issue.
Can you give it a try now?
BTW, the profile looks awesome
Postby jon.191023 » Sun Feb 11, 2024 10:04 pm
IT WORKS NOW. Thx a lot for your help.
Thx also for your feedback on the profile. :mrgreen:
It was a lot of work & I accidentally delete it during a test of sensor.
I was very scary than my backup was no longer usable.
I'm gonna share it soon. Maybe you would like to appreciate it on your personnal device. 8-)
jon.191023
