Bar Gauge
Bar Gauge
Postby kbuchwitz » Sat Jan 27, 2024 9:45 pm
How can I set a bar gauge so that the starting value starts at 4000 rpm.
My AIO pump can only be controlled between 4000-5500 rpm. I would like it that way because at an rpm of 4000 the bar gauge shows 0% and at 5500 rpm it shows 100%.
Thanks in advance.
kbuchwitz
Re: Bar Gauge
Postby TheLaGmAn » Mon Jan 29, 2024 1:11 pm
bar gauge doesnt have a mimum value but what i would do is create a VisualScripting code that if the value is > 4000, it deducts 4000, then you would have a gauge with the correct fill value (although the number now will be 0 to 1550), so u set the maximum value to 1550.
The only thing left is to show the pump actual value instead of 0-1550, you could just add a sensor value and put it on top of the gauge or some other place
