USB port Motherboard
Postby hartmutenton » Fri Jan 12, 2024 5:41 am
Can I use the USB3.2 Gen2 Port from the Motherboard :?:
hartmutenton
Re: USB port Motherboard
Postby TheLaGmAn » Sun Jan 14, 2024 8:27 pm
it provides up to 900ma which might not be enough, and for sure it will not be enough for a profile with some unit cpu usage, its is recommended that in this case you use the SATA adapter
