Profils
Profils
Postby hartmutenton » Fri Jan 12, 2024 5:02 am
Can change between Profiles automatic :?:
hartmutenton
Re: Profils
Postby TheLaGmAn » Fri Jan 12, 2024 3:18 pm
Yes, in the profile options, you can set the activation type to be of an app, meaning, when you run this specific app on your computer, that profile will become active
Re: Profils
Postby hartmutenton » Tue Jan 16, 2024 6:16 am
I think we misunderstand. Example: I create 3 Profiles and I want them show in a random, mean Profile 1 30Seconds show Profile 2 30Seconds show Profile 3 30Seconds and start again with Profile 1.
hartmutenton
Re: Profils
Postby TheLaGmAn » Tue Jan 16, 2024 5:16 pm
Ah, no, thats not possible at the moment, you can only automatically load profiles on app detection.
For sensors detection, you could create groups to achieve something similar, but you would need a sensor that decides what group to show
