Feature Request Thread
Postby Clone003 » Tue Jan 02, 2024 10:00 pm
Clone003
Re: Feature Request Thread
Postby Clone003 » Wed Jan 03, 2024 5:43 pm
Added: Change color of image when file is an .svg (vector)
2024-01-04: Strike-through requests that has been added
2024-01-14: Updated list. Added links for the post TheLaGmAn made for the corresponding feature request
2024-01-15: Added Request - Color groups for a profile.
Clone003
Postby TheLaGmAn » Wed Jan 03, 2024 7:56 pm
The icons feature has been added.
The dpad, it actually works when you use the arrow keys, i have added a hint of when you can use them so the user understand it better
Postby TheLaGmAn » Thu Jan 04, 2024 4:26 pm
The align on edges has been added a a selection option, cant do snap-in align but this feature should help
The default font settings is now enabled per session, you can mark the element font as default for new additions or copy its settings and paste it in other elements
the image fit type has been added too
Postby Clone003 » Thu Jan 04, 2024 6:51 pm
Thank you for the additions.
I tried to check them all out, but I don't happen to see the font and settings and icon features.
I was able to add Icons through using the <gov-ico> tag.
This is what I see on my end.
Clone003
Postby TheLaGmAn » Thu Jan 04, 2024 7:02 pm
added
Quick Buttons/Hotkey for easy copy and pasting element size and/or position
CTRL-C / CTRL-V added for copying the element, the copying of the position is used thru the align option
Element Enable - make a button to toggle it beside 'Element properties', currently in the 'Size and position' property.
Element List - indicator for hidden elements
Postby TheLaGmAn » Thu Jan 04, 2024 7:03 pm
Postby TheLaGmAn » Thu Jan 04, 2024 7:04 pm
wont be possible because we are using the image as a background, the workaround is to manually add it with the HTML element as svg code
Postby Clone003 » Thu Jan 04, 2024 7:26 pm
Clone003
Postby Clone003 » Sun Jan 14, 2024 9:52 pm
Updated list.
Clone003
