System Updates
Re: System Updates
Postby TheLaGmAn » Tue Jan 16, 2024 7:14 pm
You can now multi-select elements using the elements list bar on the right by keeping SHIFT pressed. You can also un-select them.
The ImageSensor now allows TEXT values for the thresholds to match text as well.
There is a new IconSensor that behaves the same as ImageSensor but with icons.
You can now use the keyword <e> on the magic sensor properties to perform modifications when the sensor is empty
Re: System Updates
Postby TheLaGmAn » Wed Jan 17, 2024 6:41 pm
Added option for second graph to chart line.
Added experimental undo/redo feature for changes in the elements within a profile
Used the design for the chart-line of @Clone003 and @kbuchwitz as defaults for the element.
Used the design for the gauge of @DooMknight87 as defaults for the element.
Used the design from motherboard red for the bar-gauge as defaults for the element.
Re: System Updates
Postby TheLaGmAn » Sun Jan 21, 2024 11:05 pm
You can now link elements properties to be shared, meaning, changing one of them changes the others as well, this is named "Link elements".
For example, you could link the font color of element1 to a link named "link-font-color", then also link the font color of element2 to the same link "link-font-color".
Now when you change the element1 "font color" value to "blue" ,it will also change the "font color" value of element2 to blue.
This is just for the emulator, so you can define values that affect multiple elements properties, like font colors, background colors, font sizes, or anything else.
Re: System Updates
Postby TheLaGmAn » Fri Feb 16, 2024 1:49 pm
You can now add your own TTF font
Users browsing this forum: No registered users and 11 guests
