New QoL changes:
- You can now copy/paste almost all element settings, you can right click on the element and select copy value. You can copy as many values as you want from different element settings, for example, you could copy width, height, and background color, this will retain those 3 settings in memory.
- 2024-01-07_15-09.png (7.38 KiB) Viewed 73241 times
You can single-paste options by going into another element setting of the same setting-style and right clicking and hitting paste, this behaves like ctrl-c/ctrl-v but with multiple copies at once since you can paste width, height and bgcolor since the memory retention is per setting.
But the best change of this is that you can then paste them by right clicking on an element on the emulator and selecting "apply" or select multiple elements and apply it to all the elements at once, it will then apply width, height and bgcolor to all those elements at once, meaning that now replicating element configurations for already created elements is quite easy.
You can also view the current settings stored in memory and remove the ones you dont want.
Also, a slider element has been added
- 2024-01-07_15-14.png (836 Bytes) Viewed 73241 times
