Q: Device and Data refresh rate?
Postby Clone003 » Tue Dec 12, 2023 5:11 am
Hi, just wanted to know what the refresh rate is for the screen.
And how fast it can actually update the data sensors being displayed, whether it be simple numbers or graphs.
Clone003
Re: Q: Device and Data refresh rate?
Postby TheLaGmAn » Tue Dec 12, 2023 3:22 pm
Usually sensors get updated every 1 second, but its in parallel, so you get the sense that the update happens constantly.
For plot graphs, it has a selector to keep the plot running smooth, so even if you get the updates every 1 second, the plot keeps running smoothly.
The video you see on the homepage is a 100% real video of the display, as its been recorded from the display itself, so you can see there how the numbers and effects move
Postby coldtearselectronics » Wed Dec 13, 2023 12:12 am
The hardware refresh rate of the screen is 60Hz.
You can see a video capture demo here:
https://streamable.com/emwqq3
The update of sensors is 1sec. For the graph it is set to update every 500ms (2Hz),
You can set it to update at 100ms min for smoother effect.
