No Sensors
No Sensors
Postby patrick-voelkl » Mon Dec 11, 2023 2:28 pm
Hi at all,
when i am Start Goverlay, i became this error massage an no sensors are showed. Can someone help?
patrick-voelkl
Re: No Sensors
Postby TheLaGmAn » Mon Dec 11, 2023 11:17 pm
We already had a teamviewer session to go over the issue and Its been fixed on GOverlayPlus 2.0.11, but do let me know if it appears again for some reason, and if anyone else is on 2.0.11 and encounters this issue, please let me know as well
Re: No Sensors
Postby Azyate » Wed Dec 20, 2023 3:33 pm
Hey i get nearly the same Error, but my version is 2.0.9 it says i have the latest Version where can i get the 2.0.11?
Azyate
Re: No Sensors
Postby TheLaGmAn » Wed Dec 20, 2023 3:45 pm
a message should appear when you open goverlay saying there is a new version, if it doesnt, go to Help > WhatsNew > Check for new version, see if it prompts you to update
Re: No Sensors
Postby Azyate » Wed Dec 20, 2023 4:22 pm
Thank you, the errors I'm encountering are still present. These errors originate from Open Hardware Monitor when the exe is open.
Open HM
Screenshot 2023-12-20 170535.png (10.59 KiB) Viewed 11866 times
Unfortunately, SIV is also not being recognized on my end. I have enabled it in Goverlay and SIV started but it always says that it couldn't be found.
Azyate
Re: No Sensors
Postby TheLaGmAn » Wed Dec 20, 2023 4:47 pm
can you send me an email to support@goverlay.com and we do a anydesk session to check the issue?
Re: No Sensors
Postby TheLaGmAn » Wed Dec 20, 2023 8:46 pm
thanks Azyate for helping into solving this issue.
For anyone else having issues with OHM/SIV, make sure you are on GOverlay 2.0.17
